B7500 Steering Problems
   / B7500 Steering Problems #1
waxahachie
I have a Hydrostatic drive tractor. Never any problems until this year (6yrs.ok)
When it is hot outside, around 100 deg., and I am mowing at 540pto w/2500 rpm's the steering starts to have a little bit of hesitation or scratchiness in when turning. The engine does not run hot, but obviously the hydraulic fluid does. Kubota does not have a separate oil cooler for this fluid as many others do. If I let the tractor idle for about fifteen minutes, this problem will go away for a while. Does anyone have an idea of the problem. If it is below 90 deg outside this never happens. Does anyone know if it is possible to install an auxillary oil cooler.
Any replies are greatly appreciated.
   / B7500 Steering Problems #2
Your hydraulic system will typically run 100 degrees hotter than ambient temp... so at 90 degrees your fluid is most likely 190 or more...
Most hydraulic fluid is intended to run at less than 180 degrees...
So there are going to be times that you are at or beyond the limits.
Your best solution is a full synthetic fluid that will function at extremes.
There are multiviscosity fluids that are better than straight weight but still not as good with dealing with heat.
Adding a cooler to the hydraulic system that has the 3pt as the final system in the loop is not going to be simple or cheap...
If your problem is actually heat related, switch to a real synthetic hydraulic trans fluid. Every hot summer I am tempted to do just that... My L4200 has a cab so I also have an air conditioner that adds heat to my total system, got to get rid of heat... KennyV
   / B7500 Steering Problems #3
Are you sure that you dont have a hydro cooler? Our B7500 has one in front of the radiator (metal coils going back and forth).
Aaron Z
   / B7500 Steering Problems #4
The tubing in front of the radiator is the cooler . I would make sure the tubing is free of debris and dirt .
Thanks Guys for the input.
I really appreciate it.
You guys are correct. It does have cooling tubes in front of the radiator.
Replaced UDT with Super UDT today. Problem corrected.
John Deere D110 42in Riding Mower (A49461)
John Deere D110...
2010 SHOP MADE WINDMILL TRAILER (A50854)
2010 SHOP MADE...
2018 INTERNATIONAL 4300 26FT BOX TRUCK (A51222)
2018 INTERNATIONAL...
2015 MACK GU713 DAYCAB (INOPERABLE) (A50854)
2015 MACK GU713...
2013 INTERNATIONAL PAYSTAR DAY CAB ROAD TRACTOR (A51406)
2013 INTERNATIONAL...
2009 PETERBILT 340 (A50854)
2009 PETERBILT 340...
