B7500 Rear PTO Problem
   / B7500 Rear PTO Problem #1
rtrent
Orange County, NY
Kubota B7500
My rear PTO worked at one time, but I don't normally use it. Only the mid-PTO for mowing. I had a leak at the rear PTO shaft seal for a while and finally got around to replacing the seal. When I had it back together and checked everything, only the mid-pto works. The PTO shifter moves smoothly into either PTO position and I can hear gears engage in either position, but only the mid-PTO spins. Since I didn't know if it was working just before I started I thought I might have screwed up, but there really isn't anything to mess up. Take the PTO cover off, remove the old seal and replace. The shafts pulled out a bit with the cover, but they just go right back in place. Found a thread about rear PTO "linkage" adjustment on B7500 fixing a very similar symptom, but no details. Messaged member, but no reply. I can't see anything related to the linkage that would affect rear only and not mid-PTO. Does anyone know what/where the linkage adjustment is? Thx!!
2018 John Deere XUV560E 4x4 Gator Utility Cart (A50322)
2018 John Deere...
2015 KC TRAILER 130 BBL STEEL VACUUM (A50854)
2015 KC TRAILER...
1984 Trailmobile Enclosed Van Trailer (A51039)
1984 Trailmobile...
Brown BDH-750 Disc Harrow (A50490)
Brown BDH-750 Disc...
1990 Ford F800 7 Yd. S/A Dump Truck (A48081)
1990 Ford F800 7...
Pallet Fees (A50775)
