B7500 Pros and Cons After 20 Hours Of Operation
   / B7500 Pros and Cons After 20 Hours Of Operation #1
MikeFLA
Central Florida
Kubota B7500
Pros
4WD - Gives the pulling power and traction of a larger tractor in a compact size.
Power Steering - makes long hours behind the wheel comfortable.
Tractor Feel - not the feel of a big tractor but not the feel of a garden tractor…just right.
R-4’s - give good traction in the sand but doesn’t hurt my grass.
Plenty of Power - tires spin before I run out of power.
Easy on and off the tractor with the flat deck
Ground Clearance!!! This is huge for me and my property. I would have been very disappointed with anything less that what the B7500 gives me.
Handles my 60" nearly 600lb finish mower with no problems. I cut the grass at less than the 2600 rated rpms for a 540 PTO.
Cons
Does not always shift into H or L from Neutral. You have to play with the accelerator. The owners manual refers to this problem. You would think that they could figure out how to solve this. It is a pain.
The owners manual for my $39 Timex watch is more comprehensive than this high dollar tractor’s operator manual.
Checking oil is a daily event. The dipstick is difficult to reach if you don’t take off the engine side cover. I can’t imagine removing this every time you check the oil. Over time the fasteners are going to loosen up and or break. Dipstick should be accessible without removing anything.
Don’t particularly like the HST pedal arrangement. Forward is fine but I still have to feel my way to find the reverse pedal. It should be right there. Also, I have caught my pants leg on the rear pedal on more than one occasion.
Front axle hubs have a "shelf" around them. A great place for dirt, and grit to accumulate and cause front seal leaks. My Kubota dealer told me this is a common problem with this design.
There is a rattling noise under there somewhere. Hopefully I can find it.
   / B7500 Pros and Cons After 20 Hours Of Operation #2
I now have 28 hours on my B7500HST using FEL, box blade, tiller and Woods 48" rotary mower and I agree on all points. A lot of hours were by my father (retired heavy equipment operator) and we both would like to add a few comments:
My father states that this set-up can do things that it most likely wasn't intended to do. Example is clearing very rough, dense brush and small trees. Lifting loads heavier than spec'd and over-all a very "tough" tractor. Trust me, he is very critical of equipment and compliments are not often given.
Cons: I also have problems with shifting into H or L.....moving the pto lever slightly helps.
removing the panel to check the oil is a pain.
the down stop adjustment on the 3pt arms is very hard to access and set. This should be a quick thumb nut adjustment on the raise/lower lever.
the fuel bowl is very exposed when mowing heavy brush. No problem yet but is a very real possibility.
I'm also building a retaining wall and the FEL beats the living crud out of a wheel barrel. Lovin' every minute of it.
Vance
   / B7500 Pros and Cons After 20 Hours Of Operation #3
Re: B7500 Pros and Cons After 20 Hours Of Operatio
You might want to post your message under the Reviews portion of this site. You've made a lot of good points, and it would make it easier for people in the market for a tractor to find.
   / B7500 Pros and Cons After 20 Hours Of Operation #4
Should the "easy on and off the tractor with the flat deck" be under the pros or am I not understanding this one?
I would also add one more con which probably isn't an issue for you in Florida with so much sand. I find it hard to engage the differential lock pedel because it is so far back. Add to this that when you get a bit on mud on your shoes your foot will just slip off the pedal.....very frustrating!
Jeff
   / B7500 Pros and Cons After 20 Hours Of Operation #5
One very minor con: at idle the 3ph lever rattles back and forth inside the fender slot and makes one heck of a racket. Another is the color and material of the hydraulic fluid dipstick: the only sure way I've been able to check the level is to take a dark colored rag and blot the dipstick on it to reveal where the wetness is. Things that you should be handling regularly should not be made out of flimsy plastic. I'm thinking about my last tractor, 1981 B5100E, and I miss all that sheet metal.
   / B7500 Pros and Cons After 20 Hours Of Operation #6
Something you might try for that dipstick is to blow a small amount of baby powder on it (wipe it dry, then dust it with a touch of the powder). Then dip in/out. This makes it very easy to see the level, and I doubt that little tiny bits of baby powder cause any harm; will be caught in the filter anyway.
   / B7500 Pros and Cons After 20 Hours Of Operation #7
Good idea - kind of like celery salt on the rim of my Bloody Caesar /w3tcompact/icons/wink.gif.
   / B7500 Pros and Cons After 20 Hours Of Operation #8
Mike, do you really think it is necessary to check the oil level each and everytime you use a tractor, or a car for that matter? I never do. If the last time you used it, checked the oil and noticed it to be adequate, drove it for a couple of hours did not notice any oil burning (or found that through experience with your newer tractor it doesn't based on prior use), did not see any oil puddles after it sat, why would it be low. I understand the problem with old engines that burn it like fuel, but on newer equipment, I have not found it necessary to do it each and everytime. I think very few folks check the engine oil in their cars and trucks each time they hop in and go somewhere, and yet there is easily as much or more investment there and undoubtedly the engine will run at a higher RPM and run as hot. If folks insit on checking the oil each and everytime as the manuals most often say to do, thats fine, but I find it most unneccessary for me. Rat...
   / B7500 Pros and Cons After 20 Hours Of Operation #9
I found that a black magic marker made the yellow dipstick easy to read. And the hydro oil did not remove the marker from the dipstick.
   / B7500 Pros and Cons After 20 Hours Of Operation #10
Ineresting Von, I thought about that and figured the oil would remove the marker ink. I burned mine with a lighter to darken it up. With all the things I like about my Kubota, the guy that came up with yellow for that dip stick------well dip stick pretty much says it.
MarkV
2015 MACK GU713 DAYCAB (A50854)
2015 MACK GU713...
2015 FREIGHTLINER CA125SLP SLEEPER (A51219)
2015 FREIGHTLINER...
10 Ft Fork extensions (A50322)
10 Ft Fork...
(3) 15X8 RIG MATS (A50854)
(3) 15X8 RIG MATS...
Seppi Mini BMS 85 Mulcher excavator attachment (A51039)
Seppi Mini BMS 85...
Unused 2025 CFG QK16R Mini Excavator (A49461)
Unused 2025 CFG...
