B7500 oil filter
   / B7500 oil filter #1
Anonymous Poster
Epic Contributor
Couldn't get the oil filter off my B7500 when I did my first
50 hour oil change this weekend, so I just changed the oil
and left the old filter on.
Are there any tricks to loosening up the filter?
There's not too much room to grab the filter with the filter wrench, as there's "stuff" all around it. I'm afraid that if I
try too hard, the wrench will slip and I'll end up breaking something.
   / B7500 oil filter #2
Snowman, I'm sure you know that you really need to change that oil filter. The only trick to removing it is enough counterclockwise force to unscrew it. Go to your local auto parts store and buy a "Three Legged Oil Filter Wrench" or if there's a Tractor Supply Co. store nearby, theirs is part number 01-18104. Get one with the round legs, not the flat ones like Northern Tool has, and it won't slip.
Bird
   / B7500 oil filter
Thanks for the reply; I'll stop by the auto store and see if they have the three legged wrench.
If I pull the oil filter off without draining the oil pan, will oil come gushing out? Since I've already
put new oil in, if I can now just change the filter, that's what I'd rather do.
   / B7500 oil filter
Huh????
Just replace the oil again... how many quarts? A couple bucks... /w3tcompact/icons/crazy.gif
Your tractor will love ya for it.../w3tcompact/icons/blush.gif
   / B7500 oil filter
I know...it's not the cost...just curious if removing the filter
will cause oil to flow out. My guess is that it would not, as it
sits above the oil pan.
   / B7500 oil filter #6
You're guessing right, snowman. You'll only lose what's in the filter, probably a pint or less.
Bird
2015 John Deere 310SL (A47384)
2015 John Deere...
2013 Ford Explorer AWD SUV (A50324)
2013 Ford Explorer...
DIRTDOG CBX60 5' BOX BLADE (A51243)
DIRTDOG CBX60 5'...
E-Z TRENCH GROUND SAW (A51244)
E-Z TRENCH GROUND...
TEST YOUR BID BUTTON! (A51243)
TEST YOUR BID...
2023 Trailerman Gooseneck (A50514)
2023 Trailerman...
