B7500 MMM backing up, sway bar in the ground
   / B7500 MMM backing up, sway bar in the ground #1
jareddavis
Hi,
I was mowing backwards (down a hill) and didn't realize the sway bar turnbuckle had disconnected. The sway bar went into a hole as I was backing up. The bar ended up vertical in the ground.
The problem is the connecting rod that goes between the sway bar and the MMM bent into the hydraulic filter and the forward/reverse pedal. The tractor was trying to go near full speed but didn't move since the bar was stuck in the ground.
The filter case was bent enough to dump the fluid.
I turned off the engine about 15 seconds after the pedal was stuck. Fluid continued to run out for 2-3 minutes after the engine was stopped.
The tractor is stuck in my yard while I wait for a new connector rod to arrive.
I'd appreciate any and all advice about how to get the tractor back in working order.
I'm thinking about these steps:
1) Replace filter
2) Add SUDT
3) Replace connector rod
4) Start engine
5) Turn the wheel all the way to the left tol bleed the air. (?)
Update:
After I did all the steps everything seemed to be OK.
Then the raise/lower lever on the 3pt hitch became loose. The roll spring pin came out that connects the lever to the valve.
Is there a standard way to get the pin seated? I can't get a good angle with pliers. I don't think hammering the valve would be acceptable. I tried putting a temporary hitch pin in - but there seems to be too much play to activate the valve.
Any hints?
2021 Liebherr L556 (A51039)
2021 Liebherr L556...
2019 Bobcat E32i Mini Excavator (A50322)
2019 Bobcat E32i...
2019 Komatsu PC490LC Hydraulic Excavator (A49461)
2019 Komatsu...
2018 INTERNATIONAL LT625 TANDEM AXLE DAY CAB (A51219)
2018 INTERNATIONAL...
John Deere 960 Culitivator (A50514)
John Deere 960...
INGERSOLL RAND COMPRESSOR (A50854)
INGERSOLL RAND...
