B7500 Leak
   / B7500 Leak #1
gusg
Vail, AZ
B7510 with R4s
I have a 7500 with 6 hours on it. The tractor is barely a week old. I have a leak that drips down on the front of the MMM about in the middle and collects in the well of the MMM. It is either a transmission or hydraulic leak. I can't see where it is coming from but there are drops of fluid on the boot that houses a drive unit for the FWD. I can't tell if it is worse when I use the FWD or the loader. Has anyone else had this problem? I will be calling the dealer today to get him to look at it. I have stopped using the tractor for now.
   / B7500 Leak #2
That is most likely the plug in the clutch gearbox housing (it's located just above the HST driveshaft where it comes out of the housing). If the tractor doesn't have the newer style plug it tends to dry rot in a relatively short amount of time and crack. The newer plugs are designed differently to prevent this. It's a pretty easy fix. If it's the HST drive shaft output seal that's a little tougher. The tractor will need to be split to replace it. There is another seal (o-rings) that seal a transfer tube that goes back to the trans housing, it is supposed to have two o-rings, sometimes it only gets one or the o-rings are damaged during assembly. That also requires a split for repair. Hope it's just the plug. You say the tractor is just a weak old, may be older depending on how long it sat on the lot as far as the dry rot problem is concerned. One thing to keep in mind is that it is a pretty easy mistake to think it's the shaft seal leaking, split the tractor and replace the shaft seal only to find out that the plug above it was the culprit all along. If your mechanic hasn't had the "pleasure" of
finding this out the hard way you can give him a heads up. With some creative use of a long screwdriver and long neck needle nose pliers the plug can be replaced without splitting the tractor.
   / B7500 Leak
Thanks for your help. Some of it is not what I wanted to hear. My Wife thinks that if it is an extensive repair the dealer should just give us another tractor. Should I continue to use the tractor while I am waiting for the dealer? My first inclination is to let it sit for now.
   / B7500 Leak #4
Go with your instinct, if the plug is leaking it could open up more and cause a pretty severe leak. I know how you feel about having a brand new tractor split for a repair, especially this early in the game. If properly done you most likely would never be able to tell it WAS done. But you or I have no control over that in this situation. As far as getting a new tractor, that's going to be your dealers call. But don't panic yet, there is a real good chance it's going to be the plug, and if it is, there's really nothing to it.
   / B7500 Leak
Thanks for making me feel better. Unfortunately the dealer apears to have taken today off since no one is answering. I had hoped to use the tractor this weekend. I will look up and see if I can see the plug. It is just a little hard to see up there especially with the MMM there. I don't want to take the MMM off since it is acting as a fluid catcher.
   / B7500 Leak #6
It is probably the forward case plug. Get a wrench out and snug it down. I think these plugs have an o-ring type or gasket type washer--was this left off or is it damaged.
What is dry rot on a tractor?, a wooden boat yes but I never seen steel dry rot. I better go check and see if I got mushrooms growing on my 'bota /w3tcompact/icons/wink.gif /w3tcompact/icons/smile.gif . B2410, trouble free at 100 hours plus.
   / B7500 Leak
I got home from work today and tried to see where the leak is coming from. Didn't see it but I checked the transmission fluid and the dip stick is bone dry! I definetely won't be suing the tractor. Hopefully with 3 gallons in the transmission it is only about a half a gallon low.
   / B7500 Leak
I guess that was a slip that I didn't catch. I won't be "using" the tractor not "suing" the tractor. Bad day.
   / B7500 Leak
Do you have any idea where this plug might be on a 7500?
   / B7500 Leak #10
Yeah ----read the manual, the part about changing transmission fluids and filters. J
2020 John Deere 3032E Tractor Loader Backhoe (A51243)
2020 John Deere...
2020 CASE CX37C EXCAVATOR (A51242)
2020 CASE CX37C...
2013 MAXEY TRAILER MFG 100KW GENERATOR TRAILER (A50854)
2013 MAXEY TRAILER...
PORTER CABLE 150 PSI AIR COMPRESSOR (A50854)
PORTER CABLE 150...
2013 Ford F-150 4x4 Ext. Cab Pickup Truck (A48081)
2013 Ford F-150...
2012 PETERBILT 388 SLEEPER TRUCK (A51222)
2012 PETERBILT 388...
