B7500 front end noise
   / B7500 front end noise #1
Theridge
I have owned my B7500 for just over a year now. It has about 630 hours on it. This spring I started noticing a whinning type noise coming from the front right tire area. Mostly in 4 wheel drive but does it to a lesser extent in 2 wheel. Takes a little time of use before it starts and can be not happening at all when the tractor is on different and or changing grades. Any ideas what might be causing this? Thanks for the help.:)
   / B7500 front end noise #2
I have a B7500 with about the same hours and have not heard this problem. Have you checked the fluid level in the front axle? This could be why the sound changes when in 2 or 4 wheel drive and on different grades.
JohnZ
B7500
Have not in a while. I will do that. thanks.
   / B7500 front end noise #4
I think you have a bearing on the way out!
2010 SHOP MADE WINDMILL TRAILER (A50854)
2010 SHOP MADE...
Komatsu Pc200lc Excavator (A50514)
Komatsu Pc200lc...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A51219)
2018 FREIGHTLINER...
2018 FREIGHTLINER CASCADIA (A50854)
2014 PETERSON 4700B HORIZONTAL GRINDER (A51242)
2014 PETERSON...
2018 CATERPILLAR 299D2 SKID STEER (A51242)
2018 CATERPILLAR...
