B7500 "Every 2 years" Questions
   / B7500 "Every 2 years" Questions #1
Rusty
Hampton Township, Bay County, Michigan
Kubota B7500HSD-R
B7500 \"Every 2 years\" Questions
My B7500 is almost due for 400 hour service and is due for "every 2 years" items. The manual calls for REPLACEMENT of the radiator hose & clamp, fuel line (emission critical) and intake air line (emission critical, "replace only if necessary"). Have you gentlemen actually been replacing these parts every 2 years? This is my 1st CUT, but I am not used to replacing these types of parts, except as necessary. Also, there is a note in the section on coolant flush & change that says, "Do not use radiator cleaning agents when anti-freeze has been added to the cooling water." Am I correct, that this note only pertains to a system that still has anti-freeze in it, and not to a system that had anti-freeze, but which has been drained? Thanks, for your assistance! /forums/images/graemlins/smile.gif
   / B7500 "Every 2 years" Questions #2
Re: B7500 \"Every 2 years\" Questions
The only think I've done is replace filters, the radiator (due to a stick poking it).
I think I'm near 500 hours now and not too many complaints.
Bo - Thanks for the reply! I also talked with the (new) Service Manager at my dealership today. With regard to replacement of the intake air line, fuel line, and radiator hose & clamp, he said to examine them and if OK, continue to use them. Also, the note about the anti-freeze does only pertain to not adding the cleaning agent to the system before removing the anti-freeze solution. Thanks, again! /forums/images/graemlins/smile.gif
   / B7500 "Every 2 years" Questions #4
Think my B7100 is about 13 years old now. Never changed a water or air hoze. Anti freeze about every 5 years. It has 2300 +/- hours on it.
Egon
4- 6 DRILL COLLARS (A50854)
4- 6 DRILL COLLARS...
AIR POWERED TONGS (A50854)
AIR POWERED TONGS...
STIHL TS420 CUTQUICK SAW (A50854)
STIHL TS420...
Unused Delta Crash...
2014 FREIGHTLINER CASCADIA (A50854)
2014 FREIGHTLINER...
2007 John Deere TX 4x2 Utility Gator (A49346)
2007 John Deere TX...
