crbr
Veteran Member
My friend has a B7300 that shears the (rear) axle pins when he widens his wheel stance. This continues to be a problem. He assures me that he is placing the proper pins into place, however the hubs are shearing these pins more often than not. Then once the pin shears, the wheel / hub slide to the tractor frame. Has anyone had any experience with this issue, in a manner of resolving the problem?
Could the hubs or axles be worn to the point of allowing too much play (oscillation or reciprocate movement) in the hubs, creating a cut in the shear pin, causing failure of the pin?
Thank you :tiphat:
Thank you :tiphat:
