b7300 instrument panel removal
   / b7300 instrument panel removal #1
Anonymous Poster
Epic Contributor
To clarify my previous post, I'm trying to determine how to remove the panel without damaging the panel or surface it mounts to. I have a service manual but can't seem to locate exactly how to proceed. Any help would be appreciated. Thanks BL
   / b7300 instrument panel removal #2
Butch, I can't say for sure, but I think it's much like my B2710, and it sure helps to have the parts manual along with the workshop manual when you do anything to your tractor. At any rate, if it's like mine, there are two snap in tabs on either side of the "frame cover" (the gray plastic part the instrument panel in mounted in). You just remove the one big screw at the top center, then pry the two tabs loose on each side (always hate to do that; afraid I'll break something). I had to take mine off once, though, and didn't do any damage.
   / b7300 instrument panel removal #3
I took my panel off my B7500 to mount my inclinometer (spelling?) and was afraid to use any tools. I know there are two notches on top to apparently stick a screwdriver into. What I did was just wedge my fingers in on each side and gently pull until it un snapped. I figured that with this method if I did not remove something that needed it I would feel it better than if using a screwdriver. It came out with no problem and more importantly went in the same way.
Jeff
2014 International WorkStar 7400 Truck, VIN # 1HTWGAAR9EH765325 (A51572)
2014 International...
2021 Delta Redirective Crash Cushion 75000 (A51692)
2021 Delta...
2011 JACK  130BBL (A52472)
2011 JACK 130BBL...
2004 MACK GRANITE CV713 DUMP TRUCK (A51406)
2004 MACK GRANITE...
2014 KENWORTH T800 (A52472)
2014 KENWORTH T800...
