B7200 Questions
   / B7200 Questions #1
KPotts
Arkansas
Thanks in advance if you can help with a couple of questions. First do you know where I can find an owner's manual for a Kubota B7200? Next my 7200 has wide turf tires on the rear and front. Are there AG tires designed for these rims, or would I have to look for rims also? If you know a source for tires or rims that would help too.
   / B7200 Questions #2
A Kubota dealer should be able to order the manuals for you, but be warned; they are not cheap. There are some aftermarket manuals (Tractor Supply Co. for one) that may serve the purpose; a lot cheaper but not nearly as good.
And if you change from the turfs to ag tires, you will have to change rims as well; don't know where you might find them other than a dealer.
Bird
   / B7200 Questions #3
Maybe Jensales.com might be able to help w/ the manual.
Buying tires and rims your talking $$$ /w3tcompact/icons/frown.gif
Why do you wish to switch tires?
If you have a FEL I found out the truf tire make the tractor more stable,also doesn't chew up the lawn etc.. when turning in a tight area.
Have you consider tire chains for the rear tires...cheaper. /w3tcompact/icons/wink.gif
Thomas..NH /w3tcompact/icons/wink.gif
   / B7200 Questions #4
Kyle:
I decided to do the same thing you're doing in reverse (swap my Ag tires for Turfs).
Check with a Kubota dealer about rims/tires. Ask him about any aftermarket swaps he might have.
My Kubota dealer has a bunch of tires/rims "in the back" that they pull off of new tractors when the buyer wants another kind (e.g. buyer wants R4s and tractor has Ags so the dealer orders R4 tires&rims and the Ag tire/rim ends up "in the back"). They sell these "like new" (they usually have less than 50 hours on them) tire/rim sets for heavy discounts.
WVBill
2016 MACK ELITE LEU633 GARBAGE TRUCK (A51243)
2016 MACK ELITE...
2016 Nissan Frontier Ext. Cab Pickup Truck (A50323)
2016 Nissan...
Air Reel (A50774)
Air Reel (A50774)
2008 FORD F150 XL TRUCK (A51243)
2008 FORD F150 XL...
UNUSED SWICT 84" QUICK ATTACH BUCKET (A51244)
UNUSED SWICT 84"...
2020 Toro Workman HD Gasoline Utility Cart (A50322)
2020 Toro Workman...
