b7200 hydraulics
   / b7200 hydraulics #1
dusty-t
My manual says there should be a hydro outlet underneath the seat. Cant find it.Any help would be appreciated.
   / b7200 hydraulics #2
If the tractor is similar to the B7100 hst there should be a valve just below the front of the seat. This is for hydrauilc attachment I think?:D
   / b7200 hydraulics #3
As I understand it that valve is a selector valve. You can extend the hydraulic circuit via the port on this valve. The only drawback is when you select the accessory curcuit the TPH will be shut off. This would be fine to power a log splitter. I chose to run my remotes for the T&T off the power beyond port on my loader valve to avoid having to choose.
Just my 2 cents......
   / b7200 hydraulics
Thanks for replying . My 7200 has a block on the side of the engine that is used for the FEL and a remote. But the workshop manual says there should be an outlet under the seat. I took the seat assembly out and nothing!!! There is the cap for the 3ph cylinder and nothing else.I knew there wasn't a valve but was hopeing to see an allen key plug or some such thing. Anyway thanks.
2017 Jaguar F-Pace AWD SUV (A50324)
2017 Jaguar F-Pace...
2014 Dodge Charger Sedan (A50324)
2014 Dodge Charger...
Dual/Moyno Pump System (A50121)
Dual/Moyno Pump...
2007 Mercedes 4D (A50120)
2007 Mercedes 4D...
2014 BMW 328i Sedan (A50324)
2014 BMW 328i...
