B7100HST Forward pedal locks down - Why?
   / B7100HST Forward pedal locks down - Why? #1
TheExitCrash
Temecula, CA
B7100HST
I have a strange thing happening with my B7100HST. I have had it for a couple months, and I am relativily sure this was not how it worked when I first got it. When you push down the pedal to go forward it reaches a point where it is stiff, and so somewhat easy to maintain this position. But, if you give it a little more pressure, it will move slightly further, make the tractor go faster, and 'lock' into position. This might be a nice 'feature' if there was a way to 'unlock' it without pressing down on the reverse pedal, which makes the tractor 'lerch' as it is actually receiving input to go in reverse.
This has become dangerous, as both me and my 12 year old son use the tractor near the edges of steep hills, and I am afraid that it is going to lock and send one of us over the edge before we can unlock it.
Is this normal operation? Is something wrong with the transmission or pedal? If this is normal, is there a better way to unlock it than pressing the reverse pedal?
   / B7100HST Forward pedal locks down - Why? #2
The pedal shouldn't behave this way. It should return to neutral as soon as you take your foot off.
I'd check underneath the deck to see if it the linkages are binding or if you have some debris stuck in them.
Also check for a grease zerk and give it a shot of grease.
Vic
   / B7100HST Forward pedal locks down - Why? #3
Also make sure the v shaped centering piece is on the roller. If this comes off it may act like you describe. There is a nut up top on the left and behind the hydro filter that can come loose and allow this to happen.:D :D :D
Thanks guys. I will have a look when I get the chance.
V shaped centering piece and roller gets the prize.
Due to wear on the roller bar mount, the roller bar was allowed to move far enough away from the v plate to pop off and get wedged. I took the whole thing off, cleaned the roller so that it actually rolled :), and heated up and bent the roller bar just enough so that no matter how far it swayed from side to side, the roller could not slip off the v.
If and when any more wearing occurs, and it pops off again, I will just have to replace the roller bar.
Thanks guys for your help. I'm not sure I would ever have thought to look in that area. I didn't realize that that was how the pedal worked.
   / B7100HST Forward pedal locks down - Why? #7
dont foreget to grease everything up a little goes a long way o that linkage
just a fyi from someone who owns and loves one
look at link in sig line
2015 KUBOTA M5660SU 4X4 FARM TRACTOR (A51243)
2015 KUBOTA...
John Deere 7810 Tractor W/Loader (RIDE AND DRIVE) (A50774)
John Deere 7810...
FORD 7600 TRACTOR (A51243)
FORD 7600 TRACTOR...
Land Honor 3 pt Disk (A50514)
Land Honor 3 pt...
2007 Toyota Corolla Sedan (A50324)
2007 Toyota...
2017 KUBOTA SVL75-2 SKID STEER (A51242)
2017 KUBOTA...
