B7100D Clutch
   / B7100D Clutch #1
82orioles
The clutch on my tractor is giving me a headache. the tractor has 700 hrs. which seems a tad early for clutch problems. I tried adjusting freeplay and could not improve the performance.I got an estimate to replace my cluttch,pressure plate,throwout bearing etc. for $ 535.00. is this a reasonable price? I investigated parts and they ran in the $200.00 range?
   / B7100D Clutch #2
Clutches will wear according to how they are used… One hour of misuse can be equivalent to thousands of normal use… Just ride the clutch a little while doing some heavy work, you can even heat check the flywheel to the point it needs resurfaced.
On a smaller sized tractor replacing the clutch is not a big job, if you are familiar with what you are going to have to do, jump in and do it. Easy afternoon project… $500 is not too much to have it done; if you think who ever is doing the job is able to do the work. KennyV.
2006 INTERNATIONAL 7400 6X4 DUMP TRUCK (A51406)
2006 INTERNATIONAL...
5ft 3 Point Hitch Bog Harrow (A51573)
5ft 3 Point Hitch...
2012 Club Car Carryall 1 Utility Cart (A51691)
2012 Club Car...
2013 PHOENIX GLOBAL TANDEM AXLE MANIFOLD TRAILER (A52472)
2013 PHOENIX...
2000 INTERNATIONAL 9200 (A52472)
2000 INTERNATIONAL...
CATALOG UPDATES (A53084)
CATALOG UPDATES...
