B7100
   / B7100 #1
TigerfaninAR
Central Arkansas
Kubota B2320 FEL, MMM
Seems to be a few of these in the 500-800 hour range for around 5K with the belly mower. Saw one that had almost 1800 hours for cheaper, don't know if that's getting up there?
We have a property we'll be building on, hopefully start next year, so need something to mow about 5-6 acres for the next two seasons. I'll be leaving the tractor at the property so don't want anything too new.
Couple questions:
With just mowing does four-wheel vs. 2wd make difference?
Gear fine for only mowing (no fel)?
Any known things to look for with this model. Most I've seen are 1993 models.
I know it'd be cheaper to have someone just go out and cut it for me but I enjoy going out there and this looks like a good excuse. Only so many times I can go walk out there with a cup of coffee before the wife thinks I'm up to no good. Am I wrong in thinking I should be able to sell for at least 3K in two years with just some mowing time on it. Then I can get a nice new shiny one with all the new attachments once we move in.:D
   / B7100 #2
B7100 are good units however given their age and your intentions I would suggest to get 4WD, a FEL, and the rear mount mower.
Reasons: 2WD reduces selling/buying/resale, FEL are expensive to add but when bouhgt with a unit are reasonable, and get a new rear mower that you can keep for your new tractor.
Hours: I would think 500-1000 are good, 1500 and up are OK, but it really depends on the owner and maintenance. Only you can determine that by looking a a few.
So you can buy a 2WD B with mower for low $ as a "starter" tractor, but I would think with the house in the near term the 4WD and Loader would serve your needs better for a few more $ today you will get a better trade in when you want to upgrade.
If of course you need to "get in low" then go with the 2wd and mower setup, then you can always justify a new unit for - snow/landscaping/grading etc, but building a house takes $ and near the end budgets tend to be tight...
   / B7100
Most the ones in my area are 4wd but hardly any have a FEL. I'll use this as a starter tractor so I can keep the place decent before we start building.
2018 KENWORTH T880 DAYCAB (A53843)
2018 KENWORTH T880...
1998 Ford F800 2,000 Gallon Water Truck (A52377)
1998 Ford F800...
2020 BOBCAT T770 SKID STEER (A52705)
2020 BOBCAT T770...
2020 CATERPILLAR 299D3 XE SKID STEER (A52705)
2020 CATERPILLAR...
2014 Ford F-150 Ext. Cab Pickup Truck (A53422)
2014 Ford F-150...
