B7100 v B7200
   / B7100 v B7200 #1
Anonymous Poster
Epic Contributor
I am going to look at two Kubotas for sale about a 3 hour drive from where I live. One is a B7100 and one a B7200. If they are equal in condition, which is the better model?
Appreciate your collective expertise on this one!
Bruce
   / B7100 v B7200 #2
According to All Makes TractorTips:
B7100 13 HP (PTO) Manufactured: 1977-1984
B7200 14 HP (PTO) Manufactured: 1983-1990
Looks like the 7200 is a newer machine and has slightly more horsepower. All other things (including price) being equal, looks like the 7200 may be the better buy.
   / B7100 v B7200 #3
Not knowing the year of the B7100 & B7200 or if they are HST or GST,I believe you may find it easier to purschase parts for the B7100 than the B7200.
I have a B7100HST that deliever 16hp at 2800rpm,also check out tractortips.com for more info.
   / B7100 v B7200 #4
Bruce,
Actually it depends upon the B7100's age.
As mentioned in one of the other posts, there was a gear drive B7100 model produced from the mid-70s to around 1984. Additionally, at least the way the story is told to me, the B7100 production stopped for one year and then resumed around 1985 through 1998 with the hydrostatic transmission (there may have been a period during the 1985-1998 production run where both gear drive and hydrostatic transmissions were available).
Obviously there were many more B7100s produced compared to the B7200 since the B7100 was in production for a much longer period than the B7200, but parts should be readily available for both.
For 4WD B7100s, the older models had a 4-lug front wheel and no ROPS; the newer models had 6 lug front-wheels and ROPS became standard equipment around the late 1980s. I THINK that the 2wd tractors all had small 4-lug front wheels.
I can't validate the year range given for the B7200 but it sounds reasonable.
B7200 Advantages: The B7200 might possibly have position control where the B7100 does not. Also, I believe that the B7200 might have a tachometer where the B7100 does not.
Other Advice: Be sure and become educated on the "thermosiphon cooling system" the B7100 uses (the B7200 probably uses the same system). With no water pump nor thermostat, it is a good system but different and you can ruin a good engine if you don't know how to perform routine maintenance (example: putting more than a 50/50 mix of antifreeze is very bad...).
Good luck and hope this information helps,
Kelvin
   / B7100 v B7200
Thanks for some great tips. I appreciate your replies
Bruce
2005 Ford F-750 Truck (A53422)
2005 Ford F-750...
2013 Mack GU813 T/A Concrete Mixer Truck (A52377)
2013 Mack GU813...
Miller Spectrum 500 DC Plasma Cutting System (A54811)
Miller Spectrum...
2009 NISSAN Murano AWD SUV (A53424)
2009 NISSAN Murano...
Case 1150G Crawler Tractor Dozer (A53421)
Case 1150G Crawler...
