B7100 type of oil for tranny
   / B7100 type of oil for tranny #1
deuce1972
Kentucky
can someone tell me what weight of oil i should use for the transmisson in my B7100 around 1980 year model and also is the oil thats in the tranny the same thats in the rear end and also for the 3 pt lift and how much does it hold and also how much engine oil does it hold also oh anyone interested in buying a Military deuce and a half i have one for sale
Thanks in advance
Troy
   / B7100 type of oil for tranny #2
My 1978 B6100 specs 90w gear oil. The manual I picked up for it has an insert from Kubota changing it over to udt. The manual also covers the B7100.
I changed my out last year and it works fine. I don't recall what the capacities are off hand. I'm at work right now, I'll try to remember to look it up for you tomorrow.
Rodger
   / B7100 type of oil for tranny #3
The original manual for the fwd gear drive tractor calls for 12.2 qts of any of the following:
Kubota UDT
Mobil Fluid 350
Exxon Torque Fluid 56
Front Differential 0.74 qt SAE 80 Gear Oil
Left and Right Front Wheel Gear Case 0.15 qt. SAE 80 Gear Oil
Recommended change is every 300 hrs.
Two drain plugs in bottom of transmission halves.
Strainer is the large center bolt in the suction pipe of the hydraulic system
I have used Amalie All Trac 245 for the last 10 or 12 years without any problems. Since the hydraulic system uses the same fluid (all one system) and I have the FEL and hydraulic dump trailer.... when I changed the fluid to Amalie I ran the tractor for a few hours after the first change and then changed it again to try to minimize any mix of different fluids. Not sure it was necessary but for the cost of the fluid it seemed to the right thing to do. I guess the proof is in the history. 22+ years without any problems except the battery which I have changed 3 times. Filters changed of course.
I have parts and owners manual so just ask if you need anything else. My B7100 is a 1983 that I have owned since new.
2022 Polaris Ranger 4x4 Utility Cart (A51691)
2022 Polaris...
2010 Ford F-150 4x4 Pickup Truck (A51692)
2010 Ford F-150...
2018 JOHN DEERE 8370R LOT IDENTIFIER 248 (A53084)
2018 JOHN DEERE...
2003 HONDA RANCHER 350 ATV (A51247)
2003 HONDA RANCHER...
2009 Freightliner M2 106 MedTec Ambulance (A51692)
2009 Freightliner...
2001 Ford Ranger Pickup Truck (A51694)
2001 Ford Ranger...
