B7100 PTO jumps out of gear in mid speed setting.
   / B7100 PTO jumps out of gear in mid speed setting. #1
SGBotsford
Bronze Member
Near Edmonton, Alberta
Deuzt 6250 + Kubota 7100
I have an ongoing love hate relationship with this bone shaker. I've had the rototiller (39") on it almost since I bought it, and I think it was off once to try to blade the driveway with a 6 foot snow blade -- an amusing exercise, as the tractor moved to the left as much as the blade moved to the right.
Anyway: Last summer when rototilling the PTO jumped out of gear in the mid speed setting. (The lever has 5 dedents with slow, neutral, medium neutral fast.) Tractor gear is 1L.
It seems to be load related. E.g. it will run ok, until I hit a slightly harder spot. I'm not torturing the poor thing. This is land that I ploughed and disked first.
Runs fine in low speed -- but that means about three passes.
Runs fine in high speed -- but that means that if I don't put in the clutch to regain revs, I stall in about 3 feet.
What should I start to look for? I've got 10 weeks to solve the problem.
If you want I'll go take pix of everything, and shove them up to flickr, or post here.
(6) Alcoa Wheels (A47384)
(6) Alcoa Wheels...
Spool 19mm Wire Rope (A47384)
Spool 19mm Wire...
2011 Ford F150 XL Pick Up (A47384)
2011 Ford F150 XL...
2025 Swict 72in Bucket Skid Steer Attachment (A50322)
2025 Swict 72in...
Wolverine Mini Skid Steer Auger Drive & Bit (A50514)
Wolverine Mini...
2019 Fecon BH74SS Hydraulic Mulcher High Flow Skid Steer Attachment (A51691)
2019 Fecon BH74SS...
