Mowing B7100 mower
   / B7100 mower #1
Anonymous Poster
Epic Contributor
Sorry if this is a repeat, will my B7100 handle a 4 ft. bush hog,that weighs 480lbs. ? The manual says to use a 42", is that being conservative or should I try to find a 42" instead of the 48" ? Thanks for the info !
   / B7100 mower #2
Gunner, I used a 4' Bush Hog Squealer on my B7100 for 4 years. As far as I'm concerned, it was exactly the right size.
Bird
   / B7100 mower #3
Gunner, I use a 4 ft. Land Pride bush hog on my B7100 with no problems at all. I run up and down some fairly good sized hills and occasionally get into some brush and sapling cutting. Like Bird, I think the 4 footer is just the right size for the B7100.
Bob Pence
   / B7100 mower #4
gunner
4' bushhog works great on my b7100 also. It's also been known to grind a few stumps(not recommended/w3tcompact/icons/wink.gif)
regards
Mutt
   / B7100 mower #5
Used a Woods XT148 4' bushhog for several years........no problem.
sk
   / B7100 mower
Thanks for the info, much appreciated ! Guess I was worried more about the weight, didn't think 6" would make that much difference in mower size. Didn't I read somewhere that the limit on the 3 pnt. was something like 300lbs.? just thought the bigger deck might be too much weight. Thanks again !
2018 JLG 3246ES 32FT. Electric Scissor Lift (A51691)
2018 JLG 3246ES...
2008 John Deere 608C combine head (A50657)
2008 John Deere...
Deere 331G (A50120)
Deere 331G (A50120)
Lot (4) 16' Light Duty Pipe Gates (A50515)
Lot (4) 16' Light...
Quick Attach 80" Rock Screening Bucket (A50514)
Quick Attach 80"...
Pickup Truck Bed (A51691)
Pickup Truck Bed...
