B7100 HST foot pedal
   / B7100 HST foot pedal #1
orwell
orwell,ny
X748
Hydro foot pedal won't go back to neutral without help. Does anyone know if this is spring loaded ? maybe a lubrication problem.
   / B7100 HST foot pedal #2
Look under your floorboard where the pedal attaches. There might be a zerk fitting there. I'm not sure about your model but my B26 and other models have a zerk on the HST pedal.
   / B7100 HST foot pedal #3
Underneath the floor pan you will find a roller that rides in a v shaped plate. This is the forward/reverse/neutral system for your tractor. Things get jammed in it. The roller comes off the plate etc.
there is an eccentric bolt adjustment on the left side accessible from the side. There is also a bolt that secures one arm that may come loose. Access through filter cover removable. And, as you will see, a spring that may have come off.
   / B7100 HST foot pedal #4
Mine was never very good at going back to neutral, in spite of lubrication and adjustments. As I recall, I isolated the issue back to play in the input shaft on the tranny.
New Bulk Lot Chain Slings (A53002)
New Bulk Lot Chain...
2016 Ford F-150 4x4 Ext. Cab Pickup Truck (A51692)
2016 Ford F-150...
2020 Peterbilt 520 Truck (A51692)
2020 Peterbilt 520...
LOT LOCATIONS (A52576)
Club Car Electric Utility Cart (A51694)
Club Car Electric...
2013 MACK ELITE LEU613 GARBAGE TRUCK (A51406)
2013 MACK ELITE...
