B7100 hst 4wd & power steering
   / B7100 hst 4wd & power steering #1
bobbyjak
Bronze Member
Oakwood, TX 75855
JD 5205 4wd
Has anyone installed or know if power steering can be installed on the B7100?..
   / B7100 hst 4wd & power steering #2
Sorry, but no PS is available for the B7100. It there was I would still own mine.
Bill Tolle
   / B7100 hst 4wd & power steering #3
I have a 2wd B6100, which is a very similar machine, and I find mine easy to steer, which makes me ask the question: does the 4wd make it harder to steer?
Also, last winter, my first winter with this tractor, I noticed the first very cold day that I couldn't steer it all the way to the left. Come to find out the steering box was full of water, which froze. The dealer I bought it from left it outside all the time, which shouldn't matter, other than I think rain water drained down the post, past a probably faulty input shaft seal, and into the 'box.
I drained it, flushed it, and put in synthetic gear oil. Works perfect ever since.
I don't leave my tractor outside, only very rarely.
   / B7100 hst 4wd & power steering #4
It is not the four wheel drive that builds character; it's the loader on the front. Without the loader they are very easy to steer.
Egon
   / B7100 hst 4wd & power steering #5
Well said. I have found that on my B7300 w/o PS it is fairly easy to steer even with a load in the FEL. It's like a car w/o PS... at a stand still... it's very hard to turn. But with just a little movement it's much easier. One time I had a lot of dirt to spread and used the FEL to back drag a lot of it. After it was all done, I realized I put blisters on my hands! So from that time on... if I have a lot of turning to do I'll wear gloves.
Kubota BX22 TLB Compact Tractor (RUNS) (A50774)
Kubota BX22 TLB...
6-CNH Rear Tractor Weights (A50774)
6-CNH Rear Tractor...
Unused 2025 CFG QK18R Mini Excavator (A50322)
Unused 2025 CFG...
2018 Ford Transit 250 (A50120)
2018 Ford Transit...
2019 Freightliner 122SD, Cummins X15 (A52384)
2019 Freightliner...
2011 Volvo Semi Truck (NOT RUNNING)(TITLE) (A50774)
2011 Volvo Semi...
