B7100 Generator / Alternator locked up
/ B7100 Generator / Alternator locked up #1
BlessedMan
Kubota B7100, M4500, & 3710
My B7100 was over heating so I replaced the head gasket and fan belt. Now my alternator/generator is locked up. Could I have the belt too tight? With wires disconnected it still will not turn.
/ B7100 Generator / Alternator locked up #2
It's not uncommon for the Kubota B7100 dynamo to have the bearings seise. To change it out remove the oil and engine rad. The dynamo itself is attached to a coolant flow housing. To get this off there will be one bolt that is difficult. Bending a combination wrench or using a ratchet combination works well. :D
/ B7100 Generator / Alternator locked up #3
I think Egon intended "remove coolant".
Be careful not to damage dynamo magnets if you need to use a puller on the front bearing.
/ B7100 Generator / Alternator locked up #4
Egon figured that removing the radiator would require all the coolant to be drained.
The Dynamo is intetegral with a coolant flow passage.:)
2022 EZ-GO ELITE...
AGT Top Cat Brush Cutter (A64047)
AGT Top Cat Brush...
2011 FORD F-550 CAB AND CHASSIS(INOPERABLE) (A65643)
2011 FORD F-550...
King Kutter II Tiller for sale.
King Kutter II...
2023 Kubota KX057-5 Compact Excavator (A63689)
2023 Kubota...
150 GALLON FUEL TANKS (A65643)
150 GALLON FUEL...
