Tires B7100 (and others) front turf tires, 20.5x8-10
   / B7100 (and others) front turf tires, 20.5x8-10 #1
jas67
Platinum Member
Central PA
Kubota B7610 + Kubota G1800-S
I have been informed by several tire vendors that this is a Kubota-special size for turf tires. It is a common trailer tire size (which would be fine for 2WD, I guess), but I have 4WD, and use it.
I need to get tires for my B7100, and have found a set of rears, but can't find fronts, other than Kubota, who is extremely proud of theirs ($180 ea!).
Any ideas where I can get them?
I also need a pair of front wheels (although, I can probably use trailer wheels) as I'm switching from ag-tire sized wheels.
Thanks,
jas67
   / B7100 (and others) front turf tires, 20.5x8-10 #2
oh wow, i'll be in the same boat here with tires....keeping an eye on this thread.
   / B7100 (and others) front turf tires, 20.5x8-10 #3
A Goodyear Dealer supplied my front turfs.:D
Do you have a model/product name?
Are they tractor/turf tires, or trailer tires.
It seems that 20.5x8-10 is a common trailer tire size, where 20.0x8-10 is a common turf tractor tire size. The trailer tires that I've seen in this size look like they'd be OK for mowing, but now for any application where you need your 4WD.
Those of us with 4WD need to have the proper 20.5" tire, as the 20.0 tire would be too small, and cause a mismatch in 4WD travel speeds, putting undue stress on the drivetrain.
Regards,
jas67
   / B7100 (and others) front turf tires, 20.5x8-10 #5
ok guys i will give u a bone here a shop call sloats tire shop got mine for me in batavia ny
they are Firestone turf and feild 20.5 x 8 x 10 the 8 is the width so mine are 8and oem are 8.5 on width they will not harm 4x4 at all they cost me 170 installed tubless and i beleive 6 ply which if u have a loader u need.
if u prepay them they MIGHT ship them to u i can not gaurentee anything though
here is there info :
Sloat's Tire Shop
(585) 343-7730
5257 Clinton Street Rd
Batavia, NY
Sloat Tire - Passenger Truck Sport Utility Commercial Tires
good luck guys
Was that each, or pair?
Thanks,
jas67
   / B7100 (and others) front turf tires, 20.5x8-10 #7
The Firestone Field & Turf 21x8-10 is a direct replacement for the 20.5x8-10. If you check the specs you will see that the diameter of the tire is indeed 20.5". I have seen them listed for around $70/tire.
Most trailer tires you find in this size don't have much of a tread and would render the 4wd pretty much useless.
Yes, I know that the trailer tires would render the 4WD useless.
Do you know where I can buy these 21x8-10 Field & Turfs?
Thanks,
Jay
   / B7100 (and others) front turf tires, 20.5x8-10 #9
Any Firestone dealer that sells AG tires should be able to order them.
   / B7100 (and others) front turf tires, 20.5x8-10 #10
ya i think that was it 21 i checked my tires but it is worn off to much spinning in mud and gravel the price i quted was for pair
2000 Ford F-150 4x4 Pickup Truck, VIN # 1FTRX18W8YNB07412 (A44391)
2000 Ford F-150...
ATTENTION PLEASE READ (A44501)
ATTENTION PLEASE...
2023 Witzco DD-40 Step Deck Trailer (A42203)
2023 Witzco DD-40...
Pallet of irrigation Hoses (A44502)
Pallet of...
2019 KENWORTH T800 (A45333)
2019 KENWORTH T800...
2014 FORD F-150 (A45046)
2014 FORD F-150...
