Buying Advice B6200 HST 4x4
   / B6200 HST 4x4 #1
South42
Amelia, Ohio
L245DT
Looking at this tractor for garden plowing/tilling and hauling/moving firewood. Rebuilt engine (bored the block and cam bearings and main bearing installed. All the pistons, rings, new oil pump, gaskets, bearings, came from Kubota.)
No mower deck and no implements.
Asking price $3500.
Hows this feel to you folks?
Also, it currently has turf tires, to swap these out with ag tires will I need to swap out the wheels as well? If so, what kind of $$ to make the swap?
   / B6200 HST 4x4 #2
The B6200 should work perfectly for the uses you describe. A word of caution though about engine rebuilds. I have rebuilt many engines and it's not uncommon to rebuild a "just rebuilt" engine. The quality of the work is just as important as the new parts being used. That said, I'd wonder why it needed a rebuild in the first place. Was it an uncommon problem or abuse? How's the rest of the machine? A quick look on Tractorhouse showed a few B6200s with low hours in the same price range. Personally, unless I knew and trusted the reputation of the rebuilder, I would rather buy a nice unmolested machine.
Tires can be pricey. The turfs should work for you unless you want to haul wood in the snow.
Good luck and I hope it all works out for you.
2002 Freightliner FL70 Sweeper Truck (NOT RUNNING) (A50774)
2002 Freightliner...
2013 INTERNATIONAL PAYSTAR DAY CAB ROAD TRACTOR (A51406)
2013 INTERNATIONAL...
2011 Manac 36245B30 45FT T/A Walking Floor Trailer (A50323)
2011 Manac...
(9) First Cutting Grass Round Bales (A50515)
(9) First Cutting...
Flatbed Equipment Trailer (A50515)
Flatbed Equipment...
John Deere 7200 Max Emerge II 16 Row Corn Planter (A52349)
John Deere 7200...
