B6100HST and ROPS
   / B6100HST and ROPS #1
Timg
I just purchased an ROPS from Kubota for my B6100HST and have an installation problem. The tractor has a mid-mount Kubota mower and the cables that raise the mower attach to linkage that is suspended from the top arms and attached to plates that are bolted onto each side of the PTO housing.
The ROPS instructions do not mention these plates and it does not appear that they can be re-installed once the ROPS is installed. The plates attach using the same six bolts on the side of the PTO housing that the ROPS uses. Has anyone encountered this problem?
   / B6100HST and ROPS #2
Timg Some of the older Kubotas had one ROPS for tractors with the mid mount mower and one ROPS for the same tractor without the mower. You should double check with your dealer and see if they offer a ROPS for the 6100 with a mid mount. I have run into this same problem at our dealership. But I dont recall if the 6100 is one of these models.
J.D.
   / B6100HST and ROPS
</font><font color="blue" class="small">( Timg Some of the older Kubotas had one ROPS for tractors with the mid mount mower and one ROPS for the same tractor without the mower. You should double check with your dealer and see if they offer a ROPS for the 6100 with a mid mount. I have run into this same problem at our dealership. But I dont recall if the 6100 is one of these models.
J.D. )</font>
Thanks J.D.,
I checked with the Kubota dealer and found that there were two different mid-mount mowers. One with lift rods that hooked to the lower arms and one(like mine) that uses cables attached to the upper arms via a linkage assembly. The dealer didn't ask for the mower serial number and simply ordered the wrong ROPS. He now has the correct ROPS on the way.
Thanks again.
TimG
2004 MACK GRANITE CV713 DUMP TRUCK (A51406)
2004 MACK GRANITE...
2019 Freightliner M2 106 Sweeper Truck, VIN # 1FVACXFC1KHKF6139 (A51572)
2019 Freightliner...
(10) Replacement Thumb Cylinders (A51573)
(10) Replacement...
2007 Hyundai Sonata GLS Sedan (A51694)
2007 Hyundai...
2011 ORTEQ ENERGY SERVICES 40 MANIFOLD TRAILER (A52472)
2011 ORTEQ ENERGY...
2019 Bobcat T590 Compact Track Loader Skid Steer (A51691)
2019 Bobcat T590...
