B6100
   / B6100 #1
sony
north central WV
B6100DT
Hi
Could anyone tell me if the B6100 engine has a thermostat? I noticed the radiator and screen in front of it had lots of plant fuzz on them.
On the same day I also changed the oil and filter. Later that day after cleaning the radiator I discovered the oil pressure light flickering while the engine was running at slow idle. I changed the sensor, but the light still comes on after a few minutes of warm up. There is no engine noise that I can discern and the light goes off when the engine rpm is increased. I don't have a temp gauge installed but the radiator seems a little warmer than before.
I used 15w40 diesel oil.
Thanks,
Sony
   / B6100 #2
If it is like my B7100 it has no water pump or thermostat. It operates on a thermo siphon principle. There should be a tube on the filler neck that comes out below the radiator pressure cap. It should end up in a whistle. When overheated the whistle goes and steam comes out. I'll attach a very poor quality pic from the manual.
Egon
2013 HINO 388 (A50854)
Set of Ag R4 Wheels and Tires (A51039)
Set of Ag R4...
2015 MACK GU713 (A50854)
2015 MACK GU713...
2016 Big Tex 14ft. T/A Hydraulic Dump Trailer (A50322)
2016 Big Tex 14ft...
Peterbilt 377 Semi-Truck (A51039)
Peterbilt 377...
434669 (A48836)
434669 (A48836)
