B6100 Mutilated Pressure Plate
   / B6100 Mutilated Pressure Plate #1
TexJer
Arlington, Tx
Kubota B6100
A couple weeks ago a friend and I replaced the clutch, pressure plate, and throwout bearing on my B6100. Admittedly I'm not the best mechanic, nor do I want to be, AND I didn't follow instructions to the Tee. After closer reading of the repair manual I realized we didn't set the finger height on the pressure plate. I'm thinking / hoping that's what caused this:
Guess it's time to get online and order another pressure plate and throwout bearing. I've seen parts manuals online for sale. Do they offer a better view of the parts and exactly how they go? The shop manual I have (I&T) only shows so much. Any suggestions there?
Anyone know of a reasonable and honest mechanic in the mid-cities part of DFW that would put this thing back together for me at my place???? I don't want to go through this again!!
   / B6100 Mutilated Pressure Plate #2
G'day sorry to see the mess :( it looks to me like the thrust brg did not release correctly I am not familiar with your machine but i would be checking any and all linkages for correct adjustment and also that they are free in all their movement if not linkage check that the master cyl is actually letting all the fluid return when you release the pedal (push thrust as far back as poss with pedal up then open bleeder and see if it will go any further if it does check m/cyl for correct adjustment). As far as an honest mechanic goes in your area can't help sorry, but then again i'm due some holidays so if you wanted to supply the tickets I could be tempted:D Best of luck with it
Jon
Howdy Jon,
It's mechanical linkage, not hydraulic. I'm thinking (dangerous) that I may have installed the throwout bearing backwards, if that's possible.
   / B6100 Mutilated Pressure Plate #4
I don't own your tractor variety, but a clutch is a clutch is a clutch.Did you adjust your pedal free play after the install;it appears the throwout bearing never released completely, heated and seized and it is all down hill from there.I can imagine you (could) install the bearing backwards, BUT, it would not be easy and should certainly look odd :confused:
   / B6100 Mutilated Pressure Plate #5
TexJer, sorry you are having issues with the replacement. I have to agree with Patches, unless you had the throwout bearing backwards I would guess the free play was off. If you have too little free play and the adjustable bolt on the arm is not set properly, you will push the TB into the fingers far enough to get stuck in them or break one. If you look at my post on my clutch replacement, you will see one of the finger bolts broke because of mal-adjustment and linkage issues which allowed the bearing to be pushed in farther than it can take. I got the machine in this state so didn't know any better. When adjusted properly, as soon as you feel the bearing against the fingers until final disengagement, is only about an inch of pedal movement. I could push my pedal a long ways when it was incorrectly set. I hope this helps.
http://www.tractorbynet.com/forums/kubota-owning-operating/114577-sad-day-my-b6100-2.html
   / B6100 Mutilated Pressure Plate #6
NH & Patches,
Thanks for the info. Yeah, I'm thinking I didn't set the pedal adjustment properly. Come to think of it, don't know if we adjusted that or not AND seeing how the old clutch was shot I'm betting they'd adjusted the pedal to the MAX trying to get it to work better.
NH, yes, that's the way I had my clutch installed. I WAS careful to look at the old one before removing and if I recall it'll only go in one way. Well, I guess you could flip it over the other way.......never say never!
Thanks for the help guys. If I get some time this weekend I'm back to the garage to get her back up and going. After some much needed rain the weeds are getting ahead of me (again).
TJ
KubotaNH,
Did you adjust the release fingers on the new pressure plate? In my I&T shop manual they talk about doing that and show some sort of measuring tool, which I can find out nothing about. They even give dimensions but I'm not sure where they are measuring from. They say to measure up from the flywheel but with the clutch plate installed I don't see how that's possible. I even asked the parts guy at my Kubota dealership about the measuring tool and he had no idea what I was talking about. Oh well........
We took the fingers off the old pressure plate and put them on the new one. One of my co-workers is a pretty good hot rod mechanic and he said the old ones didn't look that bad to him. Figured it was worth a try. The new TB will be in Monday, so it's going to be then before I can work on it.
Thanks again
   / B6100 Mutilated Pressure Plate #9
I never touched the fingers. They looked like they were adjusted at the factory so I never even gave it a thought. Did the clutch ever disengage after you did the work on it?
Keep us posted.
   / B6100 Mutilated Pressure Plate #10
I agree with Patches...a clutch is a clutch is a clutch.
You shouldn't need to set finger height...that's done during manufacturing.
There are a few things to watch for when doing a clutch job. First, make sure splines on trans input shaft are smooth. You want the friction disc to slide freely on the input shaft during clutch engage/disengage.
There MAY be a front/back orientation for the friction disc. On some clutches, the friction disc hub (with the internal splines) sticks out farther on one side of the disc than the other, and can bind on the crankshaft/pilot bearing when bolted up.
The release bearing can be installed backwards. One side has a large, flat, machined surface. That's the side that goes against the pressure plate fingers.
It is possible that the clutch release fork is not engaging the release bearing holder correctly. I'm not sure how they go together on the B6100, but on my old B6000, there were machined slots on each side of the holder that the fingers of the fork fit into.
After all is together, clutch pedal play is critical. Looking at the pic, it appears there was no play in the linkage and the release bearing was constantly riding against the clutch fingers...
2019 PETERBILT 579 SLEEPER (A51222)
2019 PETERBILT 579...
2017 POLARIS RANGER 570 4X4 PROSTAR UTV (A51406)
2017 POLARIS...
2025 78in Rock Bucket Skid Steer Attachment (A50322)
2025 78in Rock...
2017 Ford F-150 4x4 Crew Cab Pickup Truck (A50323)
2017 Ford F-150...
1973 CATERPILLAR 988 LOADER (A51222)
1973 CATERPILLAR...
2015 INTERNATIONAL 4300 26FT BOX TRUCK (A51222)
2015 INTERNATIONAL...
