B6000E Wiring Question
   / B6000E Wiring Question #1
JoelD
Veteran Member
Windham, NH and York, ME
Kioti LK3054xs TLB, 2004
neither my lights nor my horn work.
Can anyone give me a starting point on diagnosing?
I've got the wiring diagram.
One thing I'd like to figure out is how to test the dynamo (generator), it's got three wires off of it and the manual does a crappy job of telling me what each should be doing? There is a rectifier, so not certain if the the dynamo is only putting out AC or both AC and DC.
Any help is greatly appreciated.
Sincerely,
Joel
   / B6000E Wiring Question #2
My B6100 has a fuse behind the steering wheel cowling. It was broken on mine. I think it feeds the horn and lights. On the dynamo, check voltage at the battery with engine off and then started at a decent RPM. You should see a couple volts higher when running.
Thanks mike,
Ended up being the 5 amp fuse, there are two, one to the fuel pump which is 3 amp and one to the horn and lights which is 5 amp. I did not have good continuity through the fuse although did not look outright blown. Replaced fuse. Then found I did not have good ground on the lights, so direct grounded them via wire fittings rather than through hood, all is well.
Will test dynamo output this weekend.
Any idea what each of the three wires from the dynamo do?
Thanks,
Joel
Thanks, diagram looks at first blush to be identical to my wiring diagram. Just not certain how to read the three wires coming from the dynamo? I am guessing the one going to the rectifier is AC which is being converted to DC by the rectifier? (my lincoln welder has a rectifier, I think that's what it does).
I am having trouble understanding what readings I should be looking for from each of the three wires out of the dynamo, my local Kubota dealer has a B6000 wizard, I'll try to see if he knows.
I appreciate the time put into your posting the link.
Sincerely,
Joel
   / B6000E Wiring Question #6
Hey i have a kuboya b6100 and it just cut off on me and it hasnt run since and for some reason i have no pwoer at the switch but i can cross the starter over and turn over the engine but it wont run so if u got any ideas please let me know
2009 JOHN DEERE 135D EXCAVATOR (A51242)
2009 JOHN DEERE...
2012 MITSUBISHI FUSO SINGLE AXLE DUMP TRUCK (A51222)
2012 MITSUBISHI...
2012 MACK GU713 DUMP TRUCK (A51406)
2012 MACK GU713...
2016 FORD TRANSIT 250 VAN (A51406)
2016 FORD TRANSIT...
2005 WINNEBAGO WORKHORSE W22 RV (A50854)
2005 WINNEBAGO...
(INOP) NEW HOLLAND B95 BACKHOE (A50459)
(INOP) NEW HOLLAND...
