B6000 front axle pivot
   / B6000 front axle pivot #1
boxer246
Houston, TX
Kubota B6000
I dont have a maint/repair manual for the B6000 and maybe if I did, it would show me this.....but does anyone know what you are supposed to do as far as lubrication for the front axle pivot pin? The large single one under the engine, that supports the entire axle beam. I find it strange that Kubota failed to put a zerk fitting here so you could grease it. My steering is pretty loose, and while it seems to be combination of sloppy fits, one place I noticed with lots of play was that pivot pin.
Sometime I may pull it out to machine a new one, as I imagine it has alot of wear on it, hence the slop.
So is it just not supposed to be greased, or do you have to pull it each time to do so, or what?
   / B6000 front axle pivot #2
It self lubes off of the gear case oil in the front diff. If you pull that pin out you would see that it is open inside, there are o-rings to keep junk out but it should get some lube from the gear oil in there. The ring gear should sling it on to it.
2012 Ram 1500 4x4 Crew Cab Pickup Truck (A49461)
2012 Ram 1500 4x4...
2000 INTERNATIONAL 4300 17FT ROLLBACK TRUCK (A51222)
2000 INTERNATIONAL...
Morooka MST 660VD Tracked Dump Truck  Only 30 Hours (A51039)
Morooka MST 660VD...
2022 FORD F-150 LARIAT CREW CAB TRUCK (A51406)
2022 FORD F-150...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A51039)
80in HD Tooth...
2024 New Holland T8.410 MFWD Tractor (A51039)
2024 New Holland...
