B6000 Clutch
   / B6000 Clutch #1
truckster
I purchased a B6000 last year and have worked out most of the problems except for the clutch. It needs replaced and I was wondering if anyone could offer any tips on this model of tractor. I have an owners and shop manual but they are not really detailed as to replacing the clutch. This little tractor is just right for what I need and I hope it will be around for many years to come.
Thank You,
Rick
   / B6000 Clutch #2
Would you like a parts manual?
It has a bit about the clutch and may help you in future.
You probably will need to split the tractor. If you look under the little tunnel that runs forward from the gear shifter and press the clutch you will wee the slider move. This is the part next to number 19 in the picture, this gives you an idea where the clutch is.
I believe you need to split the tractor at the front of the tunnel and then you can get to the clutch to replace the necesary bits.
Hope this helps, PM me if you want the parts manual.
2025 JMR 36in Mini Skid Steer Bucket Attachment (A50322)
2025 JMR 36in Mini...
UPDATED INTERNET BUYER'S PREMIUM TERMS (A50775)
UPDATED INTERNET...
1990 Ford F800 7 Yd. S/A Dump Truck (A48081)
1990 Ford F800 7...
2014 INTERNATIONAL MA025 26FT NON CDL BOX TRUCK (A51222)
2014 INTERNATIONAL...
(INOPERABLE) CAT D4D (A50854)
(INOPERABLE) CAT...
2022 New Holland Workmaster 120 MFWD Compact Utility Tractor (A51039)
2022 New Holland...
