B6000 air filter
   / B6000 air filter #1
cappys tractor
Bronze Member
Cape Cod, Ma
B6000 4WD
Can anyone give me some insight on how my oil bath air filter is clogging the tractor so it wont run?
if i remove the filter at least it will run, but as soon as i reassemble it, it dies.
tried to clean it and put new oil in it, no dice.
any thoughts?
   / B6000 air filter #2
Are you sure you are not over filling the air cleaner with oil? It has been a while since I had my B6000 but from what I can remember it only took an ounce or so of oil.
Gary
   / B6000 air filter
i don't believe I am overfilling it, since it had trouble starting before i ever took the air filter off. the oil bath filter has a full mark line, and a arrow. confirmed by owners manual.
it appears that the level may have been low to start with, but i have made sure it is not above the full line.
i am trying to figure out how to effectively clean the steel canister part which is bolted to the engine. does it normally need cleaning? the inside looks pretty crappy. is it normal to have to remove the whole housing to clean it? do you recall having to remove the whole assembly to clean it, since you owned one?
The manual is vague about this. any past experience can help.
   / B6000 air filter #4
Cappys,
Two things come to mind.
First, where are you located??? The reason I ask is the B6000 does NOT like the cold. And any help in breathing may help it to start.
Second, I do remember fully disassembling the air cleaner to clean it. I seem to remember two clamps that held the bottom bowl in place? If this is not the case, let me know. The person I sold the B6000 lives just up the road. I can take a look to see what is involved in cleaning the filter.
It should not be a big deal to clean the filter....
Gary
   / B6000 air filter
the bottom of the filter has two spring clamps. after un clipping them, the bottom of the bowl falls down. but the upper half of the housing (which is bolted to the engine) is really crudded up. did you have to normally clean that as well as part of oil bath cleaning?
although i am not averse to taking it apart, i am wondering what is standard maintenance. this is a 31 yr old tractor so i understand that it may need 'extra' work to clean up. probably this vintage is not too user friendly, but i just am looking for any other prior experience.
while looking over other 'new' bota air filters, it seems they have changed to a re usable, cleanable, easily maintainable filter. sorta makes me jealous..... but i have to figure out old bessy first!
any thoughts you have are appreciated.
oh, forgot, Mass. and it was working, and starting fine in the recent cold weather. then yesterday when i need it to pull a couple dead trees out of the woods it called in sick! probably a little hint to me to take the day off, but did i listen?? NOPE!
   / B6000 air filter #6
I did remove the assembly shortly after I got the tractor. I seem to remember two bolts and the whole assembly comes right off. I think the screen comes off with one bolt (or possible a nut).
I used a couple of cans of Brake Parts cleaner on it and it cleaned right up.
Hope this is of some help.
Gary
   / B6000 air filter #8
If the filter was used for any length of time with the oil level too low, then the dirt that was supposed to be trapped in the oil wound up in the filter element...and is most likely restricting air flow. I would soak/swish it around in a bucket of solvent (not gasoline) until clean, and dry thoroughly before reinstalling.
   / B6000 air filter
multitude of problems. BUT SUCCESS!
thanks for your thoughts. yes, a complete disassemble and cleaning if the housing was needed. and the fuel filter was shot. while i was under the bonnet i cleaned up the battery terminals and generally tightened up things.
how/ what does the 'glow plug' indicator mean? i don't see any light or 'glow' from it on the console of the tractor. how can i test the glow plugs to see if they are working? a simple voltmeter on the top of them while turning the switch on? any idea of the correct voltage i should see?
on a related note, Carquest carries a complete line of Kubota matching fuel and oil filters and gaskets. I was pleasantly surprised to stumble across this fact. Now I don't have to drive hours to the kubota dealer for consumables!
the carquest guys said, they had to stock Kubota parts because there is such a huge amount of them out there, and they are so long lasting they always are around. THAT made me feel better about buying a 30 yr old tractor! now if my wife would understand!
on a totally unrelated note: how much should a proper counterweight in the back weigh for this size machine?
   / B6000 air filter #10
Search the site for things like "glow plug indicator" and "glow plug test"...lots of good info.
As for rear weight to counterbalance a FEL, I used to use a 300-400# rear mower...but you could need more in a 3PT weight box, depending on what you're moving...
19009 (A48082)
19009 (A48082)
2016 Case CX55B Mini Excavator (A49461)
2016 Case CX55B...
2015 JOHN DEERE 624K WHEEL LOADER (A51406)
2015 JOHN DEERE...
2013 INTERNATIONAL WORKSTAR 7600 SBA 6X4 DUMP TRK (A51406)
2013 INTERNATIONAL...
2005 Morgan Corporation Flatbed Body (A50854)
2005 Morgan...
5 Shank Inline Ripper (A50514)
5 Shank Inline...
