B414 PTO
   / B414 PTO #1
tjriddle61
mitsubishi 2501fd
Recently acquired a B414 gas tractor ans slowly getting to know the ins and outs. Is there a secret to engaging the pto lever without the grinding?
   / B414 PTO #2
When engaging the PTO I have the tractor at idle, depress the clutch, and engage the PTO. If depressing the clutch does not prevent grinding your clutch may be out of adjustment. There should be about an inch of free play at the pedal before it starts to disengage the drive.
   / B414 PTO #3
On these IHs like the 414/424/444/384 the clutch has two stages the first stage stops the movement of the tractor. Then if you push the clutch pedal down farther then the power to the PTO stops.
Per the above post yes engage/shift the PTO at idle.
Towable Orchard Sprayer (A51691)
Towable Orchard...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
2008 Freightliner B2 School Bus (A51692)
2008 Freightliner...
2021 Nissan Altima Sedan (A51694)
2021 Nissan Altima...
2009 Chevrolet Malibu Sedan (A51694)
2009 Chevrolet...
