Buying Advice B3300 BH? which one?
   / B3300 BH? which one? #1
JUBILEE1953
Bronze Member
Ohio
MF 1742 TLB - Ford NAA
Which BH goes with a B3300? Either a BH76 or a BH77. If you go through the B3300 attachment link lists it uses a BH76 which weighs 1400lbs. If you go through the attachment for B's link there is no B76 listed. All it lists is a B77 which weighs 800lbs and a BH65 which weighs 600lbs.
   / B3300 BH? which one? #2
Did you try the "Build My Kubota" configurator? Just tried it and all it allows you to add is a 7.7 foot backhoe which is the BH77. Pretty sure the BH77 replaced the BH76. But, it is possible there are some BH76 hoes still in stock somewhere so I suppose one could still buy one if they wanted one. Can't explain the weight difference, but I doubt either hoe weighs 1,400 lbs. 800lbs sounds about right for those models. I think the BH65 is for the smaller framed B's - B2320, B2620, B2920.
From Kubota Configurator
1 FRONT - 7.0 x 12.0 /REAR - 12.4 x 16.0inc.
1 FRONT LOADER PACKAGE$3,094.00
1 BALLAST BOX$245.00
1 SUBFRAME KIT FOR BACKHOE$990.00
1 7.7 FT BACKHOE$6,709.00
1 12" PIN ON BUCKET$491.00
1 6 POSITION MECHANICAL THUMB KIT$465.00
2007 Case IH 8010 4WD Combine (A50657)
2007 Case IH 8010...
2022 Chevrolet Tahoe FL SUV (A48082)
2022 Chevrolet...
2005 International TranStar 8600 Hydro Vac Truck (A50860)
2005 International...
Axle (A50860)
Axle (A50860)
Char-Broil Gas Grill (A50860)
Char-Broil Gas...
Misc. Hurricane Gates (A50860)
Misc. Hurricane...
