b3200hsd 3 point wont lift
   / b3200hsd 3 point wont lift #1
Hazzy
b3200hsd
hello i just bought a used b3200 with 2000 hrs on it and 3 point wont lift it has only had a backhoe attached to the back previously and i just bought a brush cutter for it. i opened the valve under the seat a bit and lowered it then guessing it should go back up ? my first tractor ?
   / b3200hsd 3 point wont lift #2
When you removed the backhoe, you had to disconnect at least two lines right? The lines that stay on the tractor need to be connected to each other in other to feed the 3 pt valve.
figured it out thanks anyways
yup that was the problem reconnect hoses thanks buddy
2006 Ford Crown Victoria Sedan (A50324)
2006 Ford Crown...
Skid steer auger plate (A50322)
Skid steer auger...
2019 JOHN DEERE 317G SKID STEER (A51242)
2019 JOHN DEERE...
TAKEUCHI TL8R2 SKID STEER (A51242)
TAKEUCHI TL8R2...
2022 Western Star Tri Axle Dump (A47384)
2022 Western Star...
2019 HINO 155 16FT BOX TRUCK (A50505)
2019 HINO 155 16FT...
