B3200 or L3200
   / B3200 or L3200 #1
badapplefab
CT
Kubota L3200
Does anyone have any insight about the 2 models. I don't see a big difference in the capabilties looking at the spec sheet for each, they use the same BH. The FEL has a bit more lifting capacity witht he L. I do understand that the L series is a bigger chassis and has the option of a geared transmission. The price is very similar. I also understand there is no mid PTO on the L series. But from a performance point of view what do you think.
   / B3200 or L3200 #2
The L3200 has position control while the B does not. The position control is nice setting the height for the use of 3pt implements. Just got a L3200 HST and am very pleased with it.
   / B3200 or L3200 #3
Mr. Abeal,
How well does your 3-pt. lift function? Will it go up in small increments smoothly or does it jump? I'm asking because I'm looking at the L3200 as a replacement for my L2800.
Thanks!
   / B3200 or L3200 #4
Mr. Abeal,
Thanks!
It is very smooth. Not sure if the dealer did something with it or that is how it arrived from the factory.
   / B3200 or L3200 #5
Having owned a B3200, I would be more inclined to get the L, but that would depend on your uses. What are your primary uses going to be with the tractor? For ground engaging work, the L would be better because of more weight and stronger frame, lift capacity etc. If you want to mow with a middle mount mower, or have a front implement that needs pto, then you would need the B. They are going to be fairly close performance wise.
   / B3200 or L3200
Main useages are going to ground work. Digging with bh and moving and grading with fel. No mid mount mower for my needs. I'd also be plowing with during the winter. Your answers have been helpful. Keep them coming.
   / B3200 or L3200 #7
I'd get the L then if were me. I'd also consider R-1 tires. They really turn these CUT tractor's into a whole different machine. Just keep in mind the possible jerky 3PH on the L. Lots of discussion on it here, but it may not be something that bothers you.
   / B3200 or L3200 #8
I have the B3200. I started looking at the smaller b's and worked my way up to the L series.
I wanted mine for snow clearance and clean- up work in the forest so I needed to be able to get into tight spots.
The B is great for that and is easy to maneuver for snow blowing. If you are in the wide open, the L is likely the one you need.
One word on the B3200 - there have been reports of some with bad vibrations so you should test one out throughout the rev range before purchase. Kinda like the L3200 hitch......
I'm really glad I did not go for less power!
Have fun finding the right one....
Craig
   / B3200 or L3200 #9
The vibration issue is nasty and they will only bandaid it by
adding rubber mats and isolation mounts if you ask them to
fix it and instead of simply restting the timing/shims and
installing a catalytic muffler they will do the following:
To quote them "there is no problem" (looking at you with the straight face)
with vibration BUT what they will not tell you is that the engines were detuned by advancing the injection pump timing fuel delivery to reduce thefuel and thus the emmisions at the tail pipe.
No amount of idling for warm up will cure this issue!!! Dont forget a bad low idle automaticly wins you a bad high idle at all times and the vibration is transmitted all the way back to you at the steering wheel and floor of the tractor.
No amount of weight will ever cancel or solve this issue; There has been plenty written about it here on the forum for all makes that are not direct injected.
Its an easy fix with a Kubota shop manual for the engine.
If you buy a Grand L it will be much less of an issue as the tractor is larger in horsepower.
   / B3200 or L3200
What are peoples opinions on the type of transmission, hydro or gear.
2018 CATERPILLAR 336FL EXCAVATOR (A52141)
2018 CATERPILLAR...
Kubota RTV 900 Side By Side (RUNS) (A50774)
Kubota RTV 900...
Wolverine Quick Attach Utility Hitch Adapter (A50514)
Wolverine Quick...
2019 CATERPILLAR 236D3 WHEELED SKID STEER (A51242)
2019 CATERPILLAR...
2006 Toyota Tundra 4X4 Pickup Truck (A50323)
2006 Toyota Tundra...
Quick Attach Skid Steer Quick Claw Grapple Industrial Grapple Rake (A52128)
Quick Attach Skid...
