B3200 Glow plugs and temp guage dead?
   / B3200 Glow plugs and temp guage dead? #1
parkgt
west, ar
B3200,B8200
Just noticed today that my glow plugs light does not come on with the key held over and the temp gauge is not working. Checked the fuses on the firewall and none were blown.
Where do I go from here? Is it likely for the two issues to be related to a common cause?
   / B3200 Glow plugs and temp guage dead? #2
Possibly related but not guaranteed.
Might be grounds if related, clean all ground contact points.
A voltmeter is your friend here.
Each glow plug should measure very low ohms (like 3, 4 ,5) when measured individually. Naturally 12 volts needs to get to them to work.
To measure them correctly U need to disconnect them from their 'buss bar'.
Ignition key switch also might be the cause and often due to bad internal contacts, A quirt of WD40 will help soften up the dried lubricants inside that are often the cause. (hard dry lube prevents contacts to mate)
Also on some systems the plugs do heat up but the dash indicator does not glow. If after a heat cycle plugs are warm to touch they plugs are OK.
Another 'test' is a 12 volt battery will read just that but while plugs are powered up voltage will drop to about 9 volts or so during activation.
A good battery will then shortly return a reading of 12 volts shortly.
Thanks for the reply. I will get to checking.
John Deere 506 3 pt Mower (A50515)
John Deere 506 3...
UNUSED FUTURE MINI SKID STEER MOUNTING PLATE (A51244)
UNUSED FUTURE MINI...
2020 CATERPILLAR 299D3XE SKID STEER (A51242)
2020 CATERPILLAR...
Eager Beaver (A50322)
SET OF SKID STEER QUICK ATTACH PALLET FORKS (A51243)
SET OF SKID STEER...
UNUSED AGT MX15RX EXCAVATOR (A51243)
UNUSED AGT MX15RX...
