b3000 cab fogging...
   / b3000 cab fogging... #1
tony binkowski
green bay packer land
2011 b3000
hey my cab keeps fogging up, got the fresh air open, let it warm up, any advise would be great! thx
   / b3000 cab fogging... #2
Close the fresh air. Do you have the heated windows? You might need an auxilary fan like often used in buses if you don't.
   / b3000 cab fogging... #4
Run the A/C, it will dehumidify the air even with the heat turned up.
   / b3000 cab fogging... #6
You should be fine.
E/S
   / b3000 cab fogging... #7
No-your car does the same thing in Defrost.The air passes over the heater core and the evaporator core.The cool evaporator core removes the moist air which dehumidifies the cab,then is warmed by the heater core.Sometimes it's a balancing act between enough heat and defogging as the cool evaporator core reduces the heater output.The fogging is even worse with the blower!Good Luck!
   / b3000 cab fogging... #8
Running the A/C will not hurt the HVAC system at all.
It is actually good practice to run the A/C in the winter/wet conditions to keep humidity down and it also helps to lubricate the seals in thenA/C system.
   / b3000 cab fogging... #9
Good advice..... I also set the air to 'recirculate' and run the A/C with the heat on. :thumbsup:
Wolverine TCR-12-48H SKid Steer Trencher (A47371)
Wolverine...
JMR 48in Dingo Grapple (A49251)
JMR 48in Dingo...
2018 Bobcat Planer 40PSL Hydraulic Skid Steer Attachment (A46683)
2018 Bobcat Planer...
2012 Chevrolet Impala Sedan (A48082)
2012 Chevrolet...
2017 FREIGHTLINER M2 24FT BOX TRUCK (A45678)
2017 FREIGHTLINER...
Year: 2011 Make: Ford Model: Fusion Vehicle Type: Passenger Car Mileage: 93,310 Plate: Body Type: 4 (A48082)
Year: 2011 Make...
