MattEffinCameron
prior to buying my tractor a couple years ago, and the blower last year this seemed like a pretty common setup so I am hoping someone will know this off the top of their head.
Was there any shaft length modification required to use the woods [rear] snowblower (mine is a 64" if that matters) on the B? I am also using the woods quickhitch which spaces the blower out a little more. It looks like it should be a perfect fit, but I am having a **** of a time trying to get the shaft connected to the blower (cleaned all the grease and grime off and sprayed everything with WD40 to see if that would help) and when I got that end to where I think it is on all the way, I am just short on having enough space to swing the shaft in line and attach the other end to the tractor.
I feel like im answering my question as I ask it....I should just take a few inches off the shaft...cant hurt right?
Also, if anyone has this setup can you post of a pic of what the shaft<>blower connection looks like? The button you push to slide it on is only popping out like halfway which makes me wonder if it is on all the way.
