B2910 Loader Valve
   / B2910 Loader Valve #1
littlediesel
Baldwinsville, New York
L45 TLB, U35, KX71, U17 Excavators, B3030HSDC, F3680, ASV PT40
I am looking to buy a used quick hitch/sub frame and snow blade for a B2910 that was on Ebay. The dealer tells me that you need a 4 position loader valve for this set-up. He says that the valve is marked with either a B2069 for a 3 position valve or B2079 for a 4 position valve.
The markings on my loader Valve say Husco International with no other markings that the indicate the B2069 or B2079 designation.
I can not determine what valve I have on my loader. Do any of you guys know how to determine a 3 or 4 position valve?
Thanks..
Jon
   / B2910 Loader Valve #2
Hi Jon,
I just went out and looked at my B2910. If you look under the loader valve there is a plate that the valve mounts to. On the bottom of that plate is a sticker that says B2069, and also the serial number. I would have thought that with up and down, and curl and dump, it would be a 4 way valve. I guess that's what I get for thinking /forums/images/graemlins/blush.gif
   / B2910 Loader Valve #3
It's not a 3 or 4 position valve. It's a 3 or 4 WAY valve and it has to do with the valve's internal regenerative hydraulic circuitry. See this link for more information.
3-way vs 4-way
   / B2910 Loader Valve #4
BubbaJr.
The B2069 is a three position valve, the B2079 is the four position valve on the LA402 loader. Hope this helps.
Lewis
   / B2910 Loader Valve #5
Hi Lewis,
I have a 2001 B2910 with the LA402 loader and it has the B2069 3-way valve. They may have changed to the 4 way valve since mine was made, I don't know for sure. The valves are not 3 position or 4 position, but rather 3 way or 4 way valves.
Hope this helps. /forums/images/graemlins/grin.gif
   / B2910 Loader Valve #6
BubbaJr
The Kubota whole goods book calls the valves 3 position and 4 position valves. The 4 position valve used to be optional and since 06/03 has been upgraded to be included (standard) with the LA402 loader.
Lewis
   / B2910 Loader Valve #7
Kubota's translator used the wrong hydraulic terminology thus making it confusing to the average person.
If you walked into a hydraulic shop and asked for a 3 POSITION valve you would get one that literally had 3 positions, up/neutral/down. It may or may not be 4 WAY.
Ask for a 4 POSITION valve and you would probably get asked a few more questions as the sales guy tried to figure out what you wanted since a true 4 POSITION valve is probably 2 spools.
The Kubota loader valve is actually 2 internal spools, each is 3 POSITION, with one spool having a float, and either 3 or 4 WAY.
SAKAI SV544 SMOOTH DRUM ROLLER (A52706)
SAKAI SV544 SMOOTH...
2013 International TerraStar Enclosed Service Truck with Liftgate (A53422)
2013 International...
2024 CATERPILLAR 299D3 SKID STEER (A52706)
2024 CATERPILLAR...
V.E. ENTERPRISES 500 BBL FRAC TANK (A53843)
V.E. ENTERPRISES...
3 Boxes of Laptop Briefcase Carrier (A51695)
3 Boxes of Laptop...
Peterbilt National Crane Series 900A 26 Ton Tri-axle Crane Truck (A52377)
Peterbilt National...
