Oil & Fuel B2910 Fuel Cutoff Solenoid
   / B2910 Fuel Cutoff Solenoid #1
flatfenderguy
Help! I just scored an "01" B2910 WSD with 54" 402 FEL and 54" 4-way box scraper-only 77 hours and nubbies on all four R-4's. Now the bad: owner deceased: wiring and inst. panels been destroyed by mice: key is lost: ign. sw. has been screwdrivered and starter solenoid has been hot wired with a pushbutton switch on side of cowl. The engine will start with hot wire switch and run for 1 or 2 seconds then I can hear the fuel solenoid cut off.
So...bright idea: hot wire 12V to white wire on fuel solenoid. Great! Fired up and ran for 2 whole minutes until solenoid caught fire and shut down.
Do any of you vets out there know if the "run" voltage (hold-open mode) is other than 12 V starting voltage??? Say 5 or 6 Volts?
Any assistance will be greatly appreciated. Just need to run it long enough to raise the FEL and RBS, and drive it home 1/4 mile. So that I can put it in my shop and fix it right.
Thanks in advance, flatfenderguy
   / B2910 Fuel Cutoff Solenoid #2
I just worked on a 3 cylinder kubota that had a solenoid shut off. Except when power is applied to this one it shuts it off! Might be backwards, I have no idea. For your situation I'd just take some fencing wire or equivalent and fix it in position so it will stay on. Then when you get home pull the wire out and shut it off by hand. Just an idea. My solenoid doesn't appear to be something that should have power to it continuously. Maybe that is why your's burned??
thanks Tim. Makes sense... .Bailing wire has worked for flatfenders and power wagons for years; should work on a bota, esp. if its imported wire. we'll give 'er a try this wknd.Thanks again Flatfenderguy
   / B2910 Fuel Cutoff Solenoid #4
Usually if the solenoid has three terminals it has a common and then one circuit for shut down and one for hold open to make it run.
David Kb7uns
David Kb7uns
well, removed the fried solenoid and put in right ign. key and she started right up.[I used the old style mechanical fuel shut off lever on the front side of the inj pump to kill it. Restarted and drove 'er home just like I was some kinda diesel mechanic. Dont need no stinking solenoid(just a homemade cover plate). Still gotta de-mousify the ign. wires. FFUNNNNN !!!!! At least I can play in the dirt. Thanx for your ideers, Flatfender guy.:s/biggrin.gif:D
2015 TAKEUCHI TB260 EXCAVATOR (A51246)
2015 TAKEUCHI...
(1) 12ft Tarter Gate (A51573)
(1) 12ft Tarter...
1264 (A50490)
1264 (A50490)
Year: 2010 Make: Ford Model: F-150 Vehicle Type: Pickup Truck Mileage: 81,045 Plate: Body Type: 2 (A51692)
Year: 2010 Make...
2019 CATERPILLAR 289D3 SKID STEER (A51246)
2019 CATERPILLAR...
2020 Exiss Escape 7306 LQ T/A Gooseneck Horse Trailer (A50322)
2020 Exiss Escape...
