B2910 - 3pt Hitch Load Capacity
   / B2910 - 3pt Hitch Load Capacity #1
MIKEKUBOTA
Kubota 2910
I donw't know if this is the appropriate forum to pose this question, but here it goes....
I'm thinking about purchasing 3 pt forks from sundown, but I don't know the lifting capacity of the 3pt hitch.
Does anyone have any experience using the 3pt for this type of application? Reccommendations and advice are appreciated.
   / B2910 - 3pt Hitch Load Capacity #2
Lift capacity is 1300 lbs 24" behind lift point.
I'm not familiar with Sundown forks.
Do you think I'd be putting undo stress on the 3ph if i use it as a lifting device?
   / B2910 - 3pt Hitch Load Capacity #4
The 3PH has a relief valve that only let it raise the rated weight. 3PH should be OK with that weight.
   / B2910 - 3pt Hitch Load Capacity #5
The 3pt hitch IS a lifting device! As long as you follow recommended limits and safety procedures, you should be fine.
Case-IH 370 Steiger (A50120)
Case-IH 370...
Toro ProCore 864 Series Turf Aerator Tractor Attachment (A51691)
Toro ProCore 864...
1996 Chevy 2500 - Cheyenne Edition (A50515)
1996 Chevy 2500 -...
2017 Ford Fusion Sedan (A50324)
2017 Ford Fusion...
KJ 23'x22' Double Garage Metal Shed (A50121)
KJ 23'x22' Double...
Wolverine Quick Attach 68" Bucket (A50515)
Wolverine Quick...
