B2782 Snow Blower modifying
   / B2782 Snow Blower modifying #1
bumperm
Veteran Member
Gardnerville, NV
Kubota B3350 cab & BX24
Ultra High Molecular Weight Polyethylene (or UHMW PE for short) is the strongest long chain polymer plastic available. It is also blessed with a coefficient of friction that rivals Teflon. Thus it is particularly suitable for high wear and abrasion applications where slippery is good too! Snow blowers come to mine, snow does not stick well to UHMW, so clogs, even with slushy snow, are rare. Throw distance can increase by 25%, maybe more :thumbsup:.
UHMW is a thermoplastic, so can be bent and shaped with heat, a heat gun works well, as does a propane torch if you are careful. The plastic will turn from opaque white to clear as it is heated. It must be held in place as as it is cooled. UHMW can be easily cut or machined with common woodworking tools, saws etc.
Lining the chute was the first project (and was written up in another post previously - though I think the photo links no longer work):
Last week I lined the impeller housing (hasn't been tested in the white stuff yet).
The UHMW used is 1/8" thick, 64" long by 6 - 7/8" wide. The acute angle bend (bottom in picture below or left side blower from cab), is about 35 degrees and is fully heat formed and fitted by first doing the larger bend outside the blower, then the side angles are bent and clamped in place after sliding the straight end of the UHMW into the housing in direction of impeller rotation. Then removed again. Since the liner has to be removable and insertable for fitting and replacement, (top in photo) cannot be heat formed. Instead a "V" chisel used in wood carving was used to carve a groove in the plastic on the inner surface to allow the side "ears" to be bent into position. Note the plastic isn't pulled tightly into position against the housing, but with snow pressure I'm sure it will conform - in any case not an issue.
Only the acute angle end at the "beginning" of the impeller housing is fixed in place with two 10-32 SS machine screws into drilled and threaded holes in chute (bottom of next picture). The exit end of liner (top in photo) is slotted for a single 10-32 SS screw, fender washer, and locknut - adjusted just snug. This is to allow for the thermal coefficient of expansion differential between the plastic and steel. (I put the UHMW in the freezer, measured length, then soaked it in my hot tub. The 64" length grew by 1/2", so that's how long the slot is.
Looking down the chute:
Should mention that I removed a small amount of material from the impeller blades to provide clearance for the liner. The blades were not all exactly the same length, so I used layout dye (Dy-Kem) and a divider to scribe a line off the face of the blower housing onto each blade - then had at it with angle and die grinders to get all the blades the same and a good snug fit to the liner with little friction - (a right angle air die grinder with 3M rol-loc sanding disks provided a smooth final surface to the blade ends). Dy-Kem was also useful for the grinding process as it made it easier to see where material was being removed when the dye was repeatedly brushed on the high spots.
Now where is the snow . . .
bumper
   / B2782 Snow Blower modifying #2
Wow, that's a nice clean job. I didn't think you guys got snow in the high desert.
   / B2782 Snow Blower modifying #3
Very nice work! I've been thinking about doing the same thing but I am running out of time this year. We get heavy , wet snow in this area and the UHMW PE lining would be the hot set up. Please update your thread as throughout the winter.
   / B2782 Snow Blower modifying #4
I like your idea. Very nice work!
Thanks for the compliments.
I live up against the eastern flank of the Sierra near the south end of Lake Tahoe. We get some lake effect snow and since we're in the shadow of the mountains, what we get is often slow to melt. I've seen 2 to 3 feet, not much by eastern standards I know, but still worth blowing. We've had two bleak years and some are thinking we may get hammered this year - - I hope, well, within reason anyway. If we don't, I may have to load up the tractor and head east to help you guys just so I can play in the snow some. This sitting on the tractor in the garage making engine noises is not getting it.
   / B2782 Snow Blower modifying #6
Wow. Very nice. After 8 years of gravel wear and tear on my impeller housing that may be a good material to reline it with some day. P.s. we got pretty good snow during the last big el nino in 97-98 so the buzz may not be too far off.
   / B2782 Snow Blower modifying #7
Nice looking job ----------Did you use the 1/8 " thickness in all locations?
Thanks,
Thanks,
Yes. But there's a caveat . . . when you look at the deflector, you'll notice that the plastic goes on each side of the chute and so it will not fit unless there is 1/4" slop between the deflector and the chute where the deflector sides overlap the chute. This is not a high wear area, so thinner sheet will be fine if 1/8" won't fit. BTW, those radiused slots are easiest to cut with a sabre saw after drilling the end holes - - I tried to get fancy and do it with an end mill cutter, not so good unless going to the trouble of setting it up on an index table to do in the mill (too much set up hassle)!
On this size blower, as posted in the copy, the circumference of the impeller housing requires about 64" length. I was not able to find a partial sheet for sale that had the required dimension (partial sheets offered for sale seem to max at 48"), so bought a full 96" X 48" sheet from "Plastics International" for $109 plus $40 shipping. Note that they were at first going to ship me the sheet *flat* and charge me $120 shipping!!! I said no way, it's thin, roll it up please! They said they would try and they called me back with the $40 price and it came nicely rolled up. If you want to get it flat again for cutting etc. just lay it in the sun.
I would have preferred to cut off the strip I needed on my table saw, but it would take a large table or 3 people to do that safely without having the sheet yanked. I marked a line and cut it with a saber saw, good enough.
Smaller sheets are available on Amazon etc.
   / B2782 Snow Blower modifying #9
Aaron,
I've been using UHMW tape (acrylic adhesive, not rubber) on aircraft for years, so I naturally went that route first, only using it on the deflector for the test. It got torn up when the blower picked up a bit of gravel. I think I was using 6 or 7 mil, so maybe the thicker stuff would work. It naturally resists impact and abrasion (a 1" thick piece will stop a .45 round), mine was just too thin. I don't think tape would last on the impeller housing.
I've been using 3/4" thick pieces for the skids for two seasons, I'm sure they are a little thinner, but not so's to look at. The UHMW skids prevent any damage to pavers and concrete etc.
bumper
2007 FORD F-450 SUPER DUTY (A52472)
2007 FORD F-450...
2019 New Holland Workmaster 95 MFWD Compact Utility Tractor with 632TL Loader - Poultry Special (A52748)
2019 New Holland...
2019 Ford F-350 4x4 Crew Cab AutoCrane EHCPRX 3,200lb 1.5 Ton Crane Mechanics Truck (A50323)
2019 Ford F-350...
2001 Sterling L7500 Heil 12Yd T/A Dump Truck (A51692)
2001 Sterling...
2012 WESTERN STAR 4900 SB (A52472)
2012 WESTERN STAR...
2021 New Holland C327 Compact Track Loader (A52748)
2021 New Holland...
