number two
Veteran Member
- Joined
- Apr 2, 2007
- Messages
- 1,382
- Location
- Northern Lower Michigan
- Tractor
- Kubota B3030HSDC Kubota L2501HST
I've got 3 hours on my new B2782 snowblower. I see in the manual it calls for chain lubrication every 4 hours. I've been wondering what to use and how to apply it. On my previous B2660 blower,I was able to remove the chain cover by removing 2 screws,giving access to the top of the chain assembly.I could then apply lube while rotating the driveshaft to cover the whole chain. I actually used Lucas oil treatment as it was recommended by a biker friend who said it was the best and he'd tried them all.
The B2782 came from the dealer with a heavy grease on the chain. I can see the chain through the opening on the left side of the chain cover. I've also remavod the right cover to check out the chain. I guess I'd like to think I could rotate the driveshaft and apply lube,but there's that driveshaft safety cover in the way. And the auger won't readily turn as the drive ratio is too tall. I do have a can of that spray chain lube.
Your suggestions would be appreciated. Thank you in advance.
