Snow B2781A blower on a B7510HSD
   / B2781A blower on a B7510HSD #1
beoconnor
Berwick, Maine
I am wondering if anyone has used a B2781A 51inch front mount blower on a B7510HSD machine. I have had the Bx2750 blower for the past 8 years and it needs to be retired. I clear a driveway about 1400 ft long and 2 cars wide with a fan out to a 3 bay garage. The driveway is partially paved with the remainder being gravel. Therefore, the blower does take some punishment. I have seen the B2781 and it is clearly a made from a higher grade steel which is evident by it being nearly twice the weight as the BX2750. I have generally been satisfied with the lower grade model, but am considering upgrading to the heavier duty unit. Any feedback would be greatly appreciated.
   / B2781A blower on a B7510HSD #2
I used that blower for three years on my 2620. I just traded my 2620 for a 3350 and kept the blower as it is a work horse for my 400 foot gravel, sand, and rock drive. That thing is bullet-proof! I just added the drift breaker to the blower so I can clear more width and almost cover the tires. In three years I had to replace one shear bolt!
Sent from my iPhone using TractorByNet
   / B2781A blower on a B7510HSD #3
I use a B2781 on the 3pt of my BX24. Only problem is that in this config it is direct drive at 540rpm, which is not quite fast enough... doesn't throw snow far enough, especially when wet.
In your application with mid pto adapter & gearbox, it should hopefully turn the impeller closer to 1000rpm.
Pete
   / B2781A blower on a B7510HSD #4
A business customer put a B2781A on his B2400HSD last season-results were good!
He replaced his B2660 blower which was shot.
Parts were available to make it happen,although there were some issues getting the correct propeller shaft.Would make a nice upgrade!
sandyc-what is this drift breaker you speak of?
I've seen talk of drift knives and such,but never seem to remember to ask when at the dealer.
Thanks!
   / B2781A blower on a B7510HSD #5
Hi number two: the drift breaker kit bolts on both sides of the blower and is curved outward such that it adds a few inches of width to the blower intake. Guess you could think of it as a funnel shape but flat....I'll try to get some pics of it and post if I can dig it out of my barn. You have to drill holes for the breaker to attach to the side as well as for the top braces for each side. Believe they are available for most blowers. Cost is a bit north of $100 usd and is easy to install once you figure out the drawings. The sales guys can order thru the whole goods catalogue.
   / B2781A blower on a B7510HSD #6
sandyc,thanks for the info.
A picture would be great,but please do not go out of your way!
Anything to funnel more snow into the blower when the snow total is smaller is of interest.
Kenco PH9000 Self-Leveling Pipe Hook - 9,000 LB Capacity, 8FT Max Pipe Length (A51039)
Kenco PH9000...
2019 Ford F-150 4X4 (A50397)
2019 Ford F-150...
WE DO NOT GUARENTEE HOURS UNLESS WE SAY SO!!! (A50774)
WE DO NOT...
2014 UTILITY 53X102 DRY VAN TRAILER (A50046)
2014 UTILITY...
2015 JEEP PATRIOT (A51406)
2015 JEEP PATRIOT...
2018 Toyota RAV4 Hybrid XLE AWD SUV (A50324)
2018 Toyota RAV4...
