B2710 stability on slopes
   / B2710 stability on slopes #1
Mikemas
north of Pittsburgh, PA.
B2710HST, R4 w/calcium.
I went to my dealer last weekend to look for some implements for my B2100. We were soon hashing out a deal on a new B2710. We are close on the figures, but my biggest concern was how safe the new tractor with a higher center of gravity will be on my terrain. My current B2100 is extremely stable on all my slopes, but I have loaded bar-turf tires with the axles set as wide as they can go and the mid-mount mower. I also use my rear blade for additional counterweight for loader work. The B2710 seems to be about 5" taller and 4" wider with the wheels turned out.(with no adjustable axle) I am going to ask my dealer for an on site demo to determine how safe or unsafe it would be. The tractor would be equipped with loaded R4 tires, 60" mid-mount deck and loader. Sorry about the long post, but safety is paramount in my decision and I figured the good people on this board (such as Bird who made a similar upgrade) might have some input for me.
Thanks,
Mike Masarik
   / B2710 stability on slopes #2
For what it's worth , I would figure that there would not be a big difference in stability between the 2100 and the 2710. The on-site demo and test is the way to go. Some of us who discussed the general limits of side slope operation of our tractors have bought and installed tiltmeters, I have found mine to be very helpful. My B2150 and I are comfortable working on up to a 18 degree side slope, and when I go up to or over 20 degrees I look for a way to get back under 20 fast! Good luck with your 2710!
   / B2710 stability on slopes #3
I owned a B2150 before buying the 2710,My biggest concern was also the stability.Not a problem,I can take the 2710 places I would'nt take the 2150.The 2710 is much more balanced all the way around,and handles like a dream.Hope you work up a trade,I know you'll love the 2710,if you're thinking of a new mid-mount mower also,I would recommend the 72" deck.
   / B2710 stability on slopes #4
Spent a lot of time worrying about the same. From a physics view, it's taller, higher CG with less proportinional increase in track width relative to the B7500. All for not--not even a bit of concern on my hilly property. Superior to any of the L&G tractors I've had/used. agree on the 72" deck (if my dealer ever gets over to take a look at the noise it's making!).
Wear your seat belt!
   / B2710 stability on slopes #5
Mikemas,
In general, when the wheel spacing goes out 4 inches, this would be about the same stability as lowering the cg of the tractor by 2 inches. It doesn't always work out that way. For the height to go up, usually it is a change in the tires that does that rather than the tractor actually being much larger. It is humbling to go look at a Kubota in a crate, before they put the wheels on it. In general the heavier the tractor for the same wheel diameter, the more stable will be the tractor. It takes a lot of wheel diameter increase to offset moving the wheels out 4 inches! Filling the tires with liquid has a very significant effect on the tractor stability (good effect) /w3tcompact/icons/smile.gif
2017 Ford Explorer AWD SUV (A50324)
2017 Ford Explorer...
2016 Ford Explorer...
2018 DODGE GRAND CARAVAN (A51222)
2018 DODGE GRAND...
UNUSED CFG Industrial XZ20R Mini Excavator (A47384)
UNUSED CFG...
2015 F-550 Bucket Truck. (A52128)
2015 F-550 Bucket...
2001 STERLING WATER TRUCK (A51243)
2001 STERLING...
