B2710 loose throttle
   / B2710 loose throttle #1
tomzog
North Carolina
B2710,Loader ,Woods finish mower, woods box blade
My b2710 has about 185hrs on it and no problems, but a couple of weeks ago the throttle arm started inching back to snail pace. Now its to the point that it won't even stay at a higher rpm. I know theres a simple fix but I can't see it and I wanted to ask someone before I went into the dash (and if that is what I have to do, what would be the best way.)
Thanks Tom H.
   / B2710 loose throttle #2
I can't help but will be interested in hearing the answer. My B2910 has about 218 hours on it, and the throttle has always been pretty tight. Not THAT bad, but I was looking at it today wondering myself if there was an adjustment somewhere that I could use to loosen it just a tad...
Same question, coming in from the other side I guess...
   / B2710 loose throttle #3
My B2910 is tight too. It moves freely when I first start out, then as it warms up it gets progressively tighter until I have to bang on it with my fist to make slight throttle changes. I have just gotten to the point where I accept it and go on. But if there is an easy way to fix it, I'm all ears.
   / B2710 loose throttle #4
This is a manual for the B2710 - should be able to find the exploding diagram that may help you figure out how to tighten/loosen it
web page
HELI STRAIGHT MAST FORKLIFT (A51242)
HELI STRAIGHT MAST...
2015 JOHN DEERE 744K-II HIGH LIFT WHEEL LOADER (A51242)
2015 JOHN DEERE...
AGT drum mulcher SSFM81 Attachment (A50322)
AGT drum mulcher...
UNUSED AGT MH12RX EXCAVATOR (A51243)
UNUSED AGT MH12RX...
UNUSED CFG Industrial QK18R Mini Excavator (A47384)
UNUSED CFG...
