B2710 ground wire question
/ B2710 ground wire question #1
MarkLeininger
Platinum Member
Chicago suburban
Kubota 2710
Viewing the wiring under the fender for the right turn signal, there are two wires that emerge from the wiring bundle and are neatly taped back against the wiring bundle, both unconnected to anything. One is a black wire with a large circular connector on the end, the other is a red wire with a plastic connector of some kind on the end that looks like it probably accepts a male plug-in connector. The black wire is obviously intended to be a ground connection but isn't connected to anything. Is this for some additional accessory like a work light or something, or did they just forget to connect this?
thanks
/ B2710 ground wire question #2
I hooked the black wire up to black or ground wire for my rear work light. It has a plastic housing.
It was not hooked up to anything on my B2910 either.
/ B2710 ground wire question #3
I have a B2710 with the Kubota work light. I believe those connections are for that light.
300 GALLON PULL TYPE NITROGEN APPLICATOR (A63290)
300 GALLON PULL...
CASE TR340B SKID STEER (A64279)
CASE TR340B SKID...
John Deere 7000 Planter (A63109)
John Deere 7000...
48” Titan Skid Steer Root Grapple – SSQA – Excellent Condition
48” Titan Skid...
(APPROX. 18) 27' 26G - 5V GALVALUME TIN PANELS (A63290)
(APPROX. 18) 27'...
2023 John Deere 8R 370 Tractor (A63109)
2023 John Deere 8R...
