B2710 Deal
   / B2710 Deal #1
Pozzman
MO
1702 Yanmar
I found a 2000 B2710 with 350 hrs and 60 in mmm, the owner is asking $7999. Is this a good price?
   / B2710 Deal #2
Yes, unless it was abused, then it is probably a fair deal. Check tractor house.com. I have a 2910-great tractor.
   / B2710 Deal #3
I agree. That sounds like a good price to me. I bought my B2710 in 1999; first one I saw, but had to sell it and move back to town in 2002, but it was a fine little tractor.
   / B2710 Deal #4
Like Bird, I bought a B2710 in 1999. Ten years and 820 hours later its still a great tractor. No way I'd sell mine for that, even if I took the loader off.
   / B2710 Deal
B2710
This Saturday I am going to look at a B2710, 4wd, HST with 60" bellymower. It is either a 2000 or 2001 with about 370 hours.
What things should I look for (good and bad) when inspecting the tractor?
Also, does Kubota still make a FEL for this tractor and would the tractor be able to handle a 2 blade 14" washboard plow?
Any and all input would be much appreciated.
   / B2710 Deal
Re: B2710
Sorry..I meant moldboard (bottom) plow not washboard.
   / B2710 Deal #7
Re: B2710
If properly weighted it should be able to pull it but I wouldn't want to head out to do four or five acres. The tires also enter in here as turfs might not work to good.
   / B2710 Deal #8
Re: B2710
Ask alot of questions concerning service and use. Are they original purchaser? Operate all functions of MMM and forward and reverse movement of tractor. Try it on hills up and down. Visually inspect lower parts of mowing deck and under the tractor. Ask more questions. Check all fluids for recent changes or black. Ask more questions. If not original purchaser then ask alot of questions concerning original owner. If you find any scratches, rub your finger over them and keep coming back to the scratches but never say anything.:) I've bought alot of cars.:) Ask if they'll give any kind of guarantee then ask what the price is again.:) Be sure and ask alot of questions.:)
   / B2710 Deal
Looked at the B2710 today
I went to look at the B2710 this morning was in decent shape (hood had a few scratches) engine was clean. It ran very good in all ranges forward and reverse and up and down hills without a hitch.
However, when cutting the grass which was pretty thick and about 8-9 inches high, level ground, the engine really bogged down, killed the tractor a couple of times. Upon inspection of the blades they were very dull. I was able to wrap my hand around the blade and squeeze without feeling and sharpness, the blades were very rounded.
I am a little concerned about it bogging down in such low grass or could this be due to the dullness of the blades and nothing to worry about. Any input would be greatly appreciated, I have 24 hours to let the owner know if I want to buy it.
By the way, the tractor has about 670 hours and he is asking $7000.
   / B2710 Deal #10
You started 3 separate threads, all on this same topic, so I merged them into one. When you want to update or add something to a discussion, instead of starting a completely new thread, go to the old one and click on "Reply". You can "reply" to yourself even and that'll keep the whole discussion together.
As for the mowing, I didn't have a mid-mount mower myself, but with the Bush Hog RDTH60 (60" 3-point finish mower), I've mowed grass that was over a foot tall and the tractor never bogged down. I did find out that I could go fast enough to run over some without doing a good job of cutting it, but at normal mowing speeds, 12" grass was no problem at all. And with a 5' brush hog, I've mowed Johnson Grass that was taller then the tractor with no problem.
2001 J ODell 16ft Enclosed T/A Trailer (A51691)
2001 J ODell 16ft...
Adams 5T HC Spreader (A55301)
Adams 5T HC...
2023 Bobcat T66 (A50120)
2023 Bobcat T66...
2017 Ford F-450 Crew Cab Mason Dump Truck (A53422)
2017 Ford F-450...
UNUSED WOLVERINE JMR-22-8.5G 1R RIPPER (A54757)
UNUSED WOLVERINE...
