B2650 question?
   / B2650 question? #1
bluefin650
Bronze Member
Southern Maine
Kubota B2650, JD 35D
I have a 2650 with 10hrs on it. When I got the tractor, I was using a front mount snowblower on it. When I would scroll through the display to get to the mid pto screen, it would display pto speed at 540-560rpm. Now when I am using the mid pto ONLY, the rear pto screen displays the pto speed at 540-560rpm and the display screen for the mid pto displays engine rpm along with the normal display screen that displays engine rpm. I had my dealer pick up the tractor to check it out. The tractor was dropped back off today so I checked the display. No change. I called the dealer and I was told that this was the normal operation of the display. I am not buying the explanation. The manual says Mid PTO speed for the display.
So, What do you guys say in your display when you are running the mid pto and on the mid pto display screen?
   / B2650 question? #2
I've never checked mine. When mowing I just crank it up to at least 2000 RPM, and mow. I never had a PTO speed indicator on my old B2910, and I can't think of a situation where I would actually use it.
Just enjoy the tractor, and don't worry about the small stuff. :)
Joe
   / B2650 question? #3
The mid PTO runs much faster than 540-560, so I'm guessing the display has only ever read the rear PTO based on your description. Setting the rear to 540 RPMs is very likely to also set the desired Mid PTO rpm.
   / B2650 question? #4
Normal. Your mid PTO matches engine RPM. Your rear is around 565 at max throttle.
   / B2650 question?
Thanks, I went back and re read the manual. I misunderstood it the first time
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A50322)
2025 Kivel 48in...
S Houle WD-10B Pull-Behind Hydraulic Turf Aerator Tractor Attachment (A49461)
S Houle WD-10B...
2012 MACK PINNACLE (A50854)
2012 MACK PINNACLE...
2016 JLG 3248RS 32ft Electric Scissor Lift (A50322)
2016 JLG 3248RS...
IF YOU BID ON AN ITEM YOU MUST PAY FOR IT!! NO BACKING OUT AFTER IT IS SOLD!! (A50774)
IF YOU BID ON AN...
STORAGE FEES (A51219)
