B2650 Hydraulic problem
   / B2650 Hydraulic problem #1
DaveS1108
East Aurora, NY
Kubota B2650
While using the tractor today, cleaning up after taking down some trees, the hydraulics stopped working.
Symptoms:
The only circuit that works is the bucket curl. The 3 point, bucket lift, and 3rd function for the loader are all non-operational. If I shut it down, and start it up and use the bucket lift, it lifts a little (1/8 inch) and that's it. Pressing the up/down buttons on the 3rd function, I don't hear the "clicking" that is normally heard when pressing them.
Any ideas what to look for? The hydraulic level is fine, I don't see any obvious leaks or hear any unusual sounds. The tractor moves forward/reverse fine
Thanks!
   / B2650 Hydraulic problem #2
Is your 3ph lever in the extreme "up" mode?....move it to the lower or neutral position first
   / B2650 Hydraulic problem #3
Similar situation on my x-2620.
The return hydraulic line, for the backhoe, had been disconnected by a stray branch. I was bushhoging and did not have the backhoe in place.
Check ALL hydraulic quick connects.
Sent from my iPhone using TractorByNet
After doing a little more playing around, I can get the bucket lift to work, if I am operating the bucket curl. Still nothing on the 3-point, moving the lever up/down doesn't do anything. I suspect it has to do with the 3rd function - the light on the button is lit, but there is no clicking when pressing the other 2 buttons.
Yes! That was it. The quick-connect was not fully engaged, pushed it in all the way and now everything is working great. Thank you!
2011 BMW 5 Series 550I GT Sedan (A50324)
2011 BMW 5 Series...
2006 INTERNATIONAL MA045 DAY CAB (A51219)
2006 INTERNATIONAL...
Mk Diamond MK-101 Wet Tile Saw (A49461)
Mk Diamond MK-101...
DODGE PICKUP BUMPERS (3) (A50854)
DODGE PICKUP...
2014 Therm Dynamics TD400 Towable Flameless Heater Trailer (A49461)
2014 Therm...
1998 Ford F800 Water truck (A49461)
1998 Ford F800...
